Kabeer isn't breaking any rules (though he
can be a bit mischeevy, the little scamp). No, he's enjoying the freedom that comes from having a headphone with lots of excursion, i.e., diaphragm motion. The Wharfedale Isodynamic, aka the ID1, is unique in this regard. It's a semi-ribbon driver,
semi because the magnets are fore and aft, like a normal ortho's, instead of on either side of the diaphragm. This means it can move more air than any other iso/ortho we know of. There's a surplus of bass, so dealing with the backwave isn't as critical as it is with the constrained diaphragms we're used to with orthos. Some bass cancellation is taking place, of course, but it's not the problem it is otherwise. With good heavy earpads like the Stax, it would be interesting to measure how far down this setup can go (since cancellation increases as the frequency decreases).
We tend to think of earcups and pads as necessary, but what they really are is necessary evils. If you have enough diaphragm excursion, you can do nutty things, like do away with cups and pads. Yamaha did this with their YHDs. They had to abandon their "pinch" type drivers to do it, but do it they did. And if you have never heard one, and the opportunity presents itself, do audition an old Sennheiser HD 414 or 424, the first cupless/padless headphones. Keep in mind that they were designed in the late 1960s.
