marsiswaiting
Ah man, I just bought these, but what everyone is saying about the lack of lows bothers me. If I don't get on with them, will the Fostex TH series be more what I'm looking for?
No idea about the Fostex. Though I can tell you both the M1060 v2 and M1060c had more bass extension than the Aivas. Though the bass imaging was good, the smallness of the bass was off puttingAh man, I just bought these, but what everyone is saying about the lack of lows bothers me. If I don't get on with them, will the Fostex TH series be more what I'm looking for?
Thanks for the reply. I'll look into thoseNo idea about the Fostex. Though I can tell you both the M1060 v2 and M1060c had more bass extension than the Aivas. Though the bass imaging was good, the smallness of the bass was off putting
Great! I'll have to judge for myself. I do like the new Tool album, so if you like it with the Aiva, I probably willI don't find the Aiva to lack low end at all! I use the updated perforated pads. I find the Aiva to be a highly enjoyable sigature, especially with modern pop music, but even classic rock. I own an Aiva and an LCD2C and will be keeping both!
When it comes to the new Tool album I actually prefer the LCD2C!Great! I'll have to judge for myself. I do like the new Tool album, so if you like it with the Aiva, I probably will
Or with the same source and amp other headphones like the M1060 and M1060c had a much wider soundstage......The only thing Aiva may lack is a good source. Without a good source and a good amp, the soundstage collapsed and hence people think it has small soundstage
Yeah, when I want to listen to Tool, Aiva would not be on the list. Though I only have the old stuff. Man the times I put their albums in my cart and just deleted them. Like $20 for cd? I know the pieces fit, but $20....When it comes to the new Tool album I actually prefer the LCD2C!
Can you take off the grills of the M1060? Its a super simple mod. Sure, I get it if you may return it, but know that the sound can improve with the turn of a screw driver.Hey, Folks,
I have a pair of Aiva's that I bought used from a Head-fi'er (great experience, by the way) and just took delivery of the Monoprice M1060. Figured I'd take advantage of their 30 day audition period to compare. I'll keep one and one is going to go. I'm not planning to mod the M1060's. I'm interested in hearing from any of you who have spent quality time with both of these cans. I'm torn. I find the Aiva's a bit more comfortable to wear, and goodness knows the build quality is better, but the M1060's have a bit wider stage, although they can also be a little bright to me.
Anyway, have at it!
Yes, I've heard of this mod... taking off the grills and removing the foam... Hm. I don't know... Thanks, though.Can you take off the grills of the M1060? Its a super simple mod. Sure, I get it if you may return it, but know that the sound can improve with the turn of a screw driver.
