- Jan 27, 2006
Ok, so you perhaps you did misunderstand. The idea is, many flaws with many amps is that they color sound. This is very similar to equalizing frequencies, which is the same as coloring sound. Buying an expensive piece of equipment to do virtually the same thing is pretty silly. However, as already mentioned, if it's a power relationship that's different, if a headphone sounds the way it does because it simply doesn't have enough power, that's different. But if the headphone is sufficiently powered, and the sound is different, then the amp is merely coloring the sound be it a quality issue or frequency preference issue. All of which are miniscule and hardly appreciable unless looking at decimal points as significant digits in terms of appreciation.
You're second statement could be true, to you, if you chose it to be. But I giggled. I always giggle when I compare $30 to $900 headphones. I feel silly for even having them. But alas, I like them. It's completely subjective and not rational.
The common misunderstanding on head-fi is that sufficient volume equals sufficiently amped. What's to say that NA Blur's m903 is neutral and yours is in fact colored? Thus your colored sound allows you to enjoy your D2000s, while NA Blur's m903 is similar to that of removing cotton wool from your ears.
"Buying an expensive piece of equipment to do virtually the same thing is pretty silly" - Does this statement ring true for headphones? If I choose to spend $1,000 on a source and $100 on headphones is this as silly or sillier than spending $100 on a source and $1,000 on headphones.
Decimal points and digits are reserved for those of whom purchase gear based on specs, if something has good specs but sounds poor is it still good?
I think what you meant to say with your reply to NA Blur was you don't believe in spending money on a source and don't believe there is a beneficial difference to be had.
