Need help choosing comfortable $70 - $80 headphones for alternative/rock
Jul 29, 2012 at 2:41 PM Thread Starter Post #1 of 14
Supertoaster
I'm going to try to take a small step forward
1. Comfort is a big concern for me. I'd like something with velour/comfortable pads that don't get sweaty/sticky/scratchy. I like both Super-Aural or Circumaural (nothing like Grados
2. I'm looking for a open headphone with a half decent soundstage for a bit of gaming and music. I do 50% single player gaming and 50% competitive. But I want something relatively bassy for music if possible
3. Portability isn't a concern
4. This is unimportant but I really like AKG headbands so maybe something that fits my needs from this company would be lovely (again this is unimportant, just threw this in here)
I use Superlux HD681 and Panasonic RP-HTF600-S ATM
Thanks.
Jul 29, 2012 at 5:11 PM Post #3 of 14
Hi,
It is difficult to find a really good open headphone at this price that isn't a Grado.
The Sennheiser HD518 costs about 130$ and satisfies all of your requirements; however, personally I would spend the extra 50$ on a HD558. Another possibility is the Audio Technica ATH-AD700 or Goldring DR150, but those don't have the best bass.
Jul 29, 2012 at 5:22 PM Post #4 of 14
Hi,
The 518 look promising. Thanks.
@ Arvan
I'm looking for an open phone, those are closed.
Jul 29, 2012 at 5:43 PM Post #5 of 14
Open, bassy...in this price range that would probably be the Fischer Audio FA-011.  The revised version from GD Audiobase has improved comfort in the pads according to the latest reports:  http://www.head-fi.org/t/545368/review-fischer-audio-fa-011-off-the-deep-end/1785  Note that I am not recommending them since I haven't heard them, just letting you know these exist if you haven't already noticed them.
There are a couple of obvious downsides.  The headphones cost $130, but I don't know shipping costs from Russia.  And you'd need to be patient, as these take a while to reach you by all accounts.
Also, you'd need an amp most likely, unless you've got a good soundcard for headphones already.
The only AKG's that might fit your needs/price would be the AKG K240 Mk II with the velour pads, but they are just over your stated price range...$133 at Amazon right now.  But the K240's are semi-open, not fully open, and while the soundstage isn't bad, it isn't huge either.  Decent bass, and I like them for gaming and movies both.  They will work ok without an amp but will improve slightly with one.
Jul 29, 2012 at 5:48 PM Post #6 of 14
How is the AKG 240's bass compared to something, lets say the Superlux HD681/668b/Panasonic rphtf600
I'll be running it out of an Asus Xonar DG. But I don't think it actually has an amp, I heard it just increases the gain?
Plus they're only $3 more and I get free shipping with amazon so :)
Jul 29, 2012 at 5:57 PM Post #7 of 14
I disliked the Pansonic HTF600 quite a lot, mostly because I didn't like the overbearing bass and the muddiness of the sound throughout.  The K240's don't have the same quantity of bass, but in terms of clarity, they are a very large step up.  Some people say these headphones have a slightly warm tone, but they are nowhere near what my Porta Pro's or CAL's have, and are closer to neutral than any of my other current headphones.  They have a slightly laid back presentation.
Never heard the Superluxes, so can't help with them.
Jul 29, 2012 at 6:39 PM Post #8 of 14
Thanks. As long as they aren't bassless.
So the AKG vs the Sennheiser 518, which is better?
Jul 29, 2012 at 11:48 PM Post #9 of 14
I have bad news. My budget just got reduced to about $80
I'll take off the velour pads on what I'm looking for as long as the pleather is comfy,soft and doesn't get sweaty or stick to your head.
I was thinking the AKG 240 (not MKII) I have some relatively comfy pads I bought for my old superlux which will fit the fit these. Are there any cans I could get for this price?
Thanks
Jul 30, 2012 at 12:06 AM Post #10 of 14
If you have tried the 668B, I dunno whether AKG 240's sound signature is very different from it. I can't find the FR Graphs. But maybe, just maybe, they are not for you. Some research is needed.
For $80 - open headphones...oh no...nothing much to say...but Grado !
Jul 30, 2012 at 12:37 AM Post #11 of 14
But I have heard they're really uncomfortable and they have a poor soundstage. I've heard the 668b/681 sound similar to Beyerdynamics.
Jul 30, 2012 at 3:01 AM Post #12 of 14
Grado's comfort is hit and miss and depends on the earpads used. The soundstage is also dependent on the earpads used, but it will never be like a Beyerdynamic DT990 or Audio Technica AD-series headphone in terms of soundstage.
Perhaps try a Takstar HI2050. There is also always the Koss UR40, but to be honest, I'm not sure either would be an upgrade over the Superluxes you have.
Jul 30, 2012 at 3:21 AM Post #13 of 14
I may just sidegrade again, Takstar looks nice and comfy and its under budget.
Jul 30, 2012 at 4:51 AM Post #14 of 14
Exactly...not sure whether its an upgrade. But can be considered.
There is a huge Grado modding community ... i am sure u will find comfort somewhere. I've seen all sorts of mods...
Anyways, cheerz !
