Yeah...
I've had my AHA-120 for a week, using my iTouch and Fiio L3 lod...
The AHA-120 with 12db gain seems to be a good match powerwise, and at my normal listening volume im at about 12-1 o'clock, but i guess my iTouchs 1V output isnt the highest...
The iTouch amped dosnt really do my Starkey's any justice, and the resolution is not that good as if the Starkeys just should be able to deliver more...
I do think i need to get a refit, as my right custom still hurts my internals, but my refit period is over and if it dosnt change soon, then ill try do get it done locally, i feel it only needs to get a small tweak to fit correctly...
My left is easy to get into place, the right is hurting before its in place, and the more i try to force it to fit right the more pain..
The bass is still a bit excessive with the switch on, and i cant just turn it on with different tracks that needs a boost, as i always focuse on it to much when i know its on...
Midrange and Highs dont stand out, and i would have liked a more forward sound...
Using the Presence switch as it says lifts mainly the midrange, but i need a lift in both the mid and highs to balance out the thicker bass with the switch on..
Im on a dap hunt now, the Hisoundaudio is the one id like to try, but main issues are the lack of storage mainly (only up to 16gb ext, and that is sometimes also a problem) and the silly ui, but its not too expensive for me to try, and im not really impressed with the sound i get right now...
