Hey Anouk!
Hi, I need a new amp for iem use at home (I cant connect them directly to my home rig).
Has anyone used this amp with a 15v external power supply in high current mode? I would like to know if it sounds as good this way as with a 9v battery because I intend it for home use. I was also wondering if anyone has ocmpared it with the arrow amp (which is also from Germany)?
I've scoured this thread, and to my knowledge, no one has powered the Stepdance with a 15-Volt external power supply. Given that 15-Volts is the absolute maximum voltage the Stepdance can safely handle, I'm personally not willing to come much closer than perhaps 14.5 Volts in a linear regulated power supply. Most regulated supplies claim their voltage will vary no more than +/- 0.5 Volts (if we can trust those specs).
I haven't seen any 14.5-Volt fixed-voltage linear regulated power supplies, but there are several
continuously variable benchtest supplies out there that would allow us to fine tune the voltage to 14.5. Aside from being bulky and expensive, I could see myself accidentally spinning the voltage control knob and frying my Stepdance, so I'm not interested in a variable-voltage supply.
I might be losing you about now, but your curiosity regarding the impact that a higher voltage external power supply could have on SQ is on target, given this quote from a January 11th e-mail I received from Jan Meier in response to similar questions I had asked him:
Jan Meier wrote:
"Yes, a good powersupply [for the Stepdance]
will definitely improve on sound quality, especially when it's supply voltage is so much higher than your battery voltage."
I've not yet powered my Stepdance with anything other than 8.4-Volt
iPowerUs 520-mAH batteries, but if Jan Meier says a higher voltage will improve sound quality, I'm not going to waste any more time finding out what he's talking about.
That said, I've discovered that perhaps the best quality linear regulated power supplies for the money, that will get us close to that 15-Volt maximum without getting too close, are several 13.8-Volt power supplies designed to operate as substitutes for 12-Volt lead acid automotive batteries (which put out 13.8-Volts at full charge).
Even the lowest amp ratings for power supplies of this type start at about 2.5 or 3-Amps continous - a current handling capacity that far exceeds the 100-milliamp maximum load imposed by a Stepdance, but that's OK - it just means we can use these supplies for other purposes if the need arises.
The
Pyramid PS3KX seems to be a favorite for owners of the Musical Fidelity V-DAC (among those who aren't willing to spend $249.00 for
Musical Fidelity's V-PSU.) Another option would be the
Pyle PSL42X, but I've ordered the
Tripp-Lite PR3/UL - a United Laboratories tested and approved 3-Amp continuous linear regulated power supply that I believe offers a lot more features for the money than the Pyramid or Pyle power supplies. At the moment, the lowest price I can find for the
Tripp-Lite PR3/UL is
at Amazon.
Jan Meier also wrote that the Stepdance doubles the internal battery's voltage when the Current Mode is set to High, just as it does with external power.
So, (these are my words, not his) a 13.8-Volt external supply with power the Stepdance at 27.6 Volts - a 63.4% improvement over the 16.8-Volts had when doubling the 8.4-Volts of a fully charged
iPowerUs 520-mAh LiPo battery (and a 212% improvement over the 13.0 volts had when doubling the 6.5 volts delivered by that same battery just before it quits working.)
Lastly, for those who might be curious, Jan Meier wrote than the Stepdance's 7500 uF capacitor that buffers battery power is still in the circuit when using an external power supply.
While I seem to be writing a book on the subject, let me just add that, if anyone concludes that they really like the difference in sound quality offered by the Stepdance when operating at higher voltages,
this is about the best (lightweight, affordable, and safe) portable solution I've found to date for operating near the 15-volt limit: The
Blue LiPo 4-Cell 1000mAh 4S1P 14.8v 20C LiPoly Battery and
a proper charger to go with it. These 14.8-Volt 1000-mAh LiPo batteries cost only $9.70 each (less than half the price of the 8.4-Volt iPowerUs internal batteries I'm currently using) and they're small enough (at 74x35x23mm) to fit into a small camera case along with the Stepdance and your DAP of choice. They will have none of the regulation and potential AC line noise problems associated with the PSU's discussed above, and they contain a chip that prevents them from being charged to voltages higher than 14.8 Volts - perfect for pushing the Stepdance to its limits. And if you're willing to carry larger, heavier, 14.8V LipP packs that work with the same charger, consider
this 1800 mAh pack, or
this 5000 mAh pack.
As with the Tripp-Lite PSU, if I eventually splurge for a 14.8-volt LiPo rig, I'll share my findings.
Edit applied on 15 February 2011 - Warning: Don't purchase any of the 14.8-Volt LiPo batteries I recommended, above - Get the 11.1-Volt LiPo batteries offered by the same retailer, instead. I've only today learned that the voltage specs for RC hobbiest batteries such as the Blue LiPo 4-Cell 1000mAh 4S1P 14.8v 20C LiPoly Battery are NOMINAL voltages! This means that a 14.8-Volt battery is READY TO BE CHARGED when it gets DOWN to 14.8-Volts! When fully charged, add 0.5 Volts per cell - which for these 4-cell batteries, equals another 2.0 Volts. So... when this 14.8-Volt battery is fully charged, it's at 16.8-Volts - FAR in excess of the 15-Volt limit for the Stepdance. If you're still interested in an external LiPo pack for the Stepdance, get the 11.1-Volt 3-cell LiPo batteries from the same retailer as linked above, or for less hassle but more bulk and weight, get the Energizer XP8000, which provides a 12.0-Volt output jack that can be used with the Stepdance. Search this thread for more info on the XP8000. Mike
Mike
