canthearyou
- Jan 27, 2015
I recently had both the Gustard X20u Pro and the Matrix Audio X-Saber Pro. I listened to both of them for a week and was able to make a decision on the better unit. I originally bought the Gustard direct from Shenzhen.com. Shortly after my Gustard order was confirmed I found a great deal on a X-Saber Pro in the classifieds that I couldn't pass up. I took the plunge and bought it as well.
First unit to arrive was the X20 Pro(less than a week from China is not bad at all). This big, black, boxy, behemoth is very utilitarian in appearance. Two knobs and a small OLED screen on the front of the unit. The usual inputs and outputs of a modern DAC finish the rear of the unit. Sharp, squared edges and many(all) allen head screws visible give it an all business look. I connected it directly to my laptop using the supplied USB cable. Turned the power knob to the on position and heard a few loud relays switch on and she powered right up. I used the same old driver for my recently sold Gustard X12/U12. It worked without a hitch. I was greeted with a powerful, dynamic sound. I was truly stunned at the difference in sound quality compared to my old DAC. It was as if a veil was lifted and everything was crystal clear. Powerful, clean bass, well balanced mids and an almost too bright top end. I quickly got used to the highs and started listening to all my favorite songs/albums for the first time, again. I really, really liked the sound. I went ahead and removed the old drivers and installed the ones provided on the thumbdrive from Gustard.
A few days later I received the X-Saber Pro and quickly opened to box to see a sleek, sexy, DAC! Smooth lines, no knobs or buttons, no visible screws. The back of the unit had the normal connections of a DAC. Just all around a very nice looking unit that was much smaller than I expected, but it weighed almost 10lbs! I installed the drivers from the website and used the same USB cable from Gustard. Once I started listening to some of my favorite songs I realized I liked the X20 Pro more. The X-Saber had a more toned down approach to reproducing the music. I also felt the soundstage was smaller in all directions. I decided to look at the menu to check out the settings. This is a rather cumbersome deal which requires holding your finger on the power button. This shuts the unit off and enters the menu. Then you have to navigate using a series of button presses. I did not like menu approach at all! After I fiddled with some menu options(filters) I turned it back on but was still underwhelmed with the sound.
I decided to try throwing some DSD at the DACs to see if one was better than the other. I configured Foobar for DSD. First problem was my current laptop didn't have the gusto to do much DSD. I was able to do DSD64 and 256(Gustard max). When I tried 512 the CPU usage was pegged and stutters and pops galore. So I grabbed my new laptop which has an Intel i5 chip. I still couldn't do much with DSD512 as any other background service would cause pops and stutters. So I set both units to 256 and gave it a few listening sessions. The Gustard seemed to perform better than the Matrix. The Matrix had more stutters and lock-ups during playback. Not sure if had something to do with the X20 using DoP2DSD and the Matrix using true DSD. To tell you the truth, when it was working I couldn't hear a difference between DSD and PCM. Plus the majority of my listening is on Tidal, so I went back to PCM.
Quick summary:
Gustard X20u Pro:Bigger, clearer, more dynamic sound. Wider, deeper soundtage. Big, boxy, all business look. Menu is super easy to navigate. $860.00
Matrix Audio X-Saber: More neutral, intimate sound. Beautiful work of machining!! I like the touch buttons. Look sexy! Menu is goofy and akward. $1600.00
Clear winner IMO is the X20 Pro. I am extremely satisfied to the unit. For half the cost of the Matrix, it bests it in the areas that matter.
Amp:Modded Matrix HPA3-B
Headphones:McIntosh MHP1000
I am gonna purchase a Singxer SU-1 and see what happens next.
P.S. I am gonna try a R2R DAC next. Looking at the Denafrips Pontus.
Quick summary:
