Loquah
I didn't find massive change with burn-in after the first hour or two. It was a little dry in the treble straight out of the box, but to my ears that cleared up really quickly.
just got mine as well, i have to admit, this was one HELL of an upgrade from my x-fi soundcard... seriously, and boy the construction of this thing is awesome!! the only thing that im not fond of is the 3 leg thing.. why?
anyways, one pretty awesome DAC that i wont have to bother with for years to come!
Three legs is or was somewhat common as an alternative to the usual four corners. Something about a triangle being more solid and rigid than a square.... I've seen it on some pretty esoteric gear in the past, though I'm not sure which companies still favor it.
hey i would suggest getting an XLR cables with RCA plug(or XLR to RCA) , trust me you will notice the difference immediately.
http://www.amazon.com/gp/product/B0013HT6JU/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
i am using this one with an RCA adapters, Huge difference, i did compare it with RCA to RCA
the X-Sabre is made to be used as a Balance DAC to begin with.
It's definitely worth using the XLRs if you have an amp that takes balanced input, but there's no need to worry about it if your amp takes unbalanced (RCA) input only. If you compensate for the much higher voltage from the XLRs, the sound is identical from both when running into an unbalanced input.
I tried this extensively with my Mainline amp by switching between the XLRs and RCAs. So long as I adjusted the volume up for the RCAs / down for the XLRs, the quality of sound was identical.
deciding whether i should pick up the x sabre or the anedio d2, both of which have units being sold in the FS forum. the x sabre is better-looking (IMHO) and has DSD, but the d2 seems to get some very high praise, though the sabre is no slouch either. i have two other DACs coming in that are both DSD-capable (pulse x and the micro iDSD, both of which should ship in the next few months) so DSD capability is not a must. hmmm...
X-Sabre uses the tech from Matrix's USB converter. Probably won't make a difference. I don't hear anything different between the inputs.
