hakuzen
- Feb 9, 2016
Could anyone link me to a 2.5mm Balance Adapter thats let me use my Balance 2.5mm Cable on standard 3.5 jack
i was looking for a good 3.5mm TRS male to 2.5mm TRRS female cable adapter, and thought that new FiiO cable was the best affordable one.
didn't try it, because decided to go for a short (no wire or minimum length possible) adapter instead. these adapters are more conductive (no wire bottleneck), but have the disadvantage of adding stress to the jack socket (specially the straight ones).
got these:
https://www.aliexpress.com/item/OKC...le-Jack-Audio-Stereo-Adapter/32865122372.html
https://www.aliexpress.com/item/-/32860629855.html
https://doublehelixcables.com/product/eidolic-2-5mm-trrs-3-5mm-trs-adapter/
http://www.norneaudio.com/litzheim/...nch-connector-gold-plated-compact-right-angle
received an straight alo audio adapter, as well, from GUCraftsman.
and this is in my cart:
https://www.aliexpress.com/item/-/32876989769.html
same process than with balanced adapters.. i ended avoiding wire, and got the short adapters. mmcx to 2pins (http://www.lunashops.com/goods.php?id=5779), and also mmcx to ATH-IM: http://www.lunashops.com/goods.php?id=5585So I just found something that is very cool. This shop on aliexpress sells hand made adapters that fit mmcx to something like HD6XX headphones. MMCX to ATH-IM series. ect. Check out their web page.
https://www.aliexpress.com/item/Fre...1f-4bea-bddb-725b5393cf6d&transAbTest=ae803_3
for HD650: http://www.lunashops.com/goods.php?id=5586
