saman65
the link doesn't open to any item.SG$ 151.13 | 1% gold + 99% pure silver + 7n OCC Litz The best mixing proportion determined by multiple mixing scheme MMCX 0.78MM
https://s.click.aliexpress.com/e/m5zPteza
So with discounts and the Hakuzen code. 175 ended up being $170. Good deal. Looking forward to it.
Mate, was it 8 core or 4 core you got for the 175?So with discounts and the Hakuzen code. 175 ended up being $170. Good deal. Looking forward to it.
"Looking for a bigger soundstage, with a more defined yet impactful bass/subbass". both accomplish this. ISN C16 is warm and bass heavy compared to both. i like 210 bass even more than 175, but they are near. quite detailed bass textures, way tighter bass than C16. boosted bass of Kanas Pro gets benefited of this bass cleanliness surely.So, right now on Aliexpress, the price difference between Oalloy and EA 175 (but in 4 core version on latter), is like $13 Cdn. I can only afford to buy one ( will use it with mostly with Moondrop KanasPro...but maybe also TFZ NO.3 or Nicehck NX7). I'm mostly leaning to pairing it with my KanasPro. Looking for a bigger soundstage, with a more defined yet impactful bass/subbass; but while also giving tonally correct mids and upper mids and highs detail. I have the ISN C16 copper on my KanasPro now (balanced, 2.5 plug); and while the bass is great, and mids are a bit warmer and fleshed out compared to the stock 3.5mm cable; I wish for a bit more detail and soundstage in the highs. So, which one would be better, @hakuzen? Cable 210 from Nicehck, or cable 175 (in 4 core, balanced version) from EA? The Electro acoustic cable is like $3 more than the Oalloy.
yes, you can.can i build my own 175 cable using?
https://www.aliexpress.com/item/33046978735.html
https://www.aliexpress.com/item/1000007631873.html
i just dont know if it is cryofrozed already...
if shop coupon codes are compatible with head-fi/hakuzen discount, $189 - $15 shop coupon code - 10%off ($17.4) - aliexpress black friday "friday10" code ($10) + $1.9 shipping = $149So with discounts and the Hakuzen code. 175 ended up being $170. Good deal. Looking forward to it.
yes, if you don't plan to use the cable with other better iem, that's a clear overkill.I've paid 150 bucks for my comet. Isn't a $175 cable overkill?! I mean is it gonna improve the sound quality considerably that justifies paying as much as the IEM's worth?
I only use my IEM for outside, 80% of the time listening to Monday Morning Podcast Billy red balls! I think 210 would be good enough of an upgrade to my current cable which is...kinda awful!
Thank you. I just bought an Aeolus and with not much more to spend, Comet should be good enough for listening on the bike where I have to wear helmet. Otherwise, I don't shy away from wearing the biggest cans outsideyes, if you don't plan to use the cable with other better iem, that's a clear overkill.
the cable doesn't improve sound quality further than your source+iem limits. the cable doesn't sound, it just degrades the different frequencies in a minor or major grade.
210 would be good enough, and also 175 4 cores version (similar price)
