I saw EAC has adapters for sale, as well. Have you tried them? I was thinking of getting a right angled MMCX to 2-pin one together with the 175 cable.
yes, i've tried them. they are the same that costed me from 25 to 35 USD some months ago at aliexpress, lunashops, and penon.
but they cost around $10 at electro acousti! (even cheaper than most taobao prices).
before this price, they were only considered for cables above 60 USD. now, you can spend 10 USD for your 30 USD cables.
they are made of gold plated brass or copper, and plastic, and measured below 2mOhm. only one of them showed a crack after some use (still working, just cosmetic issue).
the recently linked adapter from haldane or from taobao, are made of a hard resin ("egger"), thicker, harder, and more transparent, than the plastic of the cheaper adapters. gold plated copper contacts, and silver solder. they are more expensive, but better quality.
it's important to notice that these adapters are harder to plug and unplug. the connection is tighter than with the cheaper adapters. i have to use a tool to unplug the mmcx connection. so for measuring or if i have to change the adapters frequently, i use the CEMA electro acousti adapters. for more permanent connections, i use the more expensive ones.
Guys, one more thing before i go ahead with the order- SE or balanced? I know this has been debated all along. Since I am getting a new cable and have this option, which would be better(sonically should there be any).
If you get the balanced you can always use an adapter to convert to SE but not the other way around. Just a thought - balanced will give you more versatility...
Cheers,
Tim
besides of what
@CobraMan has answered, which is essential to consider (if you'll ever get a balanced source), there is a clear sound difference if you use a balanced source + balanced cable respect using single-end (besides of double power -double voltage, +6dB SPL-): crosstalk. crosstalk is decreased notably, so you get wider sound stage.
Hi, i currently have some wire from norne audio for my HD800(occ litz and the difference was huge compared to the stock cable !). i'm looking for another wires to try. What do you guys recommend ? (wire because diy and sorry for my english)
i'd suggest up-occ wires. check certified neotech wires at audiophonics.fr (or hificollective.co.uk). or oem up-occ (not certified neotech) at CEMA electro acousti shop at aliexpress (i've tried many of them and i could swear they are up-occ, judging for the sound differences respect any other wire i've tried)
