do you have a link Hakuzen ???you ought to try angled mmcx-2pin adapters, better result..
Thanks
sure.do you have a link Hakuzen ???
Thanks
Great, thankssure.
i bought mines at taobao, but now you can get them at aliexpress, Haldane shop (also available at DD-Audio/linsoul, but more expensive):
https://www.aliexpress.com/item/4000272701010.html
i own various types, and these are the best quality ones in my stock.
Haldane has a large variety of termination adapters
AnotherqQuestion Hakuzen,sure.
Haldane seems to stock chinese audio items which can be found at taobao, at a decent price (to buy at taobao, you need an agent and his cut, besides of higher shipping costs).AnotherqQuestion Hakuzen,
I'm looking for something like this
https://www.aliexpress.com/item/4000148867627.html
Is Haldane a good option to get it or should look some where else???
As usual, thanks so much, your comments are always so helpful.Haldane seems to stock chinese audio items which can be found at taobao, at a decent price (to buy at taobao, you need an agent and his cut, besides of higher shipping costs).
it's nice to find shops stocking items you only could find at taobao in the pass.
about that adapter, i've not tried it. wire doesn't look bad, and neither 6.35mm plug. but the 4.4mm socket is a cheap chinese one.
i'd better get a 4.4mm to 3.5mm male adapter, plus a decent short 3.5mm to 6.35mm adapter (they are below 3mOhm, high quality, or below 7mOhm, cheaper ones), to fit both 3.5 and 6.35mm outputs, because it's harder to find a 6.35mm to 3.5mm male adapter.
EAC adapter (number 64 in my list of jack adapters) costs near the double than the adapter of your link, but quality of plugs and wire is miles away better.
sure.
care to share the Impression?Just in
Some close ups of the 175, qdc stock cable, and local made pure silver cable respectively
from hazuken list is 171/198 pure copper depends u want how many coresI'm looking for a new cable for my IMR Zenith R1. I think I will go for a copper cable from Electro acousti or upgrade cable from IMR itself. Can someone tell me if there is difference in sound between UP-OCC and OFC cables?
Will tty to answer these by my exp. while waiting others opinion...I'm looking for a new cable for my IMR Zenith R1. I think I will go for a copper cable from Electro acousti or upgrade cable from IMR itself. Can someone tell me if there is difference in sound between UP-OCC and OFC cables?
The Faaeal Hibiscus copper Litz cable is $22.50USD. Is there a cheaper and equal option for a BQEYZ iem?
This Hibiscus iem is new but some are saying they can find the whole shebang (litz cable/iem) for $39USD on Shopee which makes me wonder if the cable is even that good...
