hakuzen
- Feb 9, 2016
back from a travel..
To fit the case you are using, you can sand off the bevel of the jack until it is 8mm: insert the jack into the mouth of your drill, as if it was a drill bit, and roll it over a sand paper (sanding 0.5mm shouldn't be hard). This way the jack will pass entirely through the hole, and length will be enough probably.
If you want a clear wire and plugs upgrade, I guess this cable is quite better than TRN or JCALLY, but it's $40:
https://www.aliexpress.com/item/4000009633191.html
You could ask the seller to use QDC termination, with or without molded ear guides:
Yea, synergy with your IEM is very important. With the pure silver UP-OCC wires, I also notice more textured and detailed bass. I wouldn't say boomer, because I perceive lower sub-bass rumble, less loose, more detailed.
Thanks for your impressions, please keep on posting them, because you own almost all UP-OCC types of wire. I know it isn't easy, but this info is gold for those doubting between copper, SPC, copper+SPC, silver, copper+silver[+SPC], etc.
I use (standard) protruding with blessing (guess they have same kind of recessed sockets than KXXS). Although it sticks a bit, the connection is firm and secure (better than flush terminations).
Maybe type G termination in the pic above (plastic angled less protruding 0.78mm pins) could fit KXXS even better. Or file the shoulders a bit (I don't use to do this).
Yeah, chin slider holes (3mm) are a bit wide for 4 cores cables. I use them, so ended adding extra chin sliders, silicone o-ring usually, or plastic chin sliders (cut to insert the wires, and then adhesive tape around to keep them inside):
I have to try 24k gold plated silver though. Guess I won't get so great highs compared to silver (AgAu) wire, but expect different (and possibly better) lows. I won't know it till I try, I should try only gold plated silver (no mix) before, to compare with the other wires properly.
I prefer sandal wood finish slightly, it's more exclusive and original, and the core of the jack is the same. But not much distance (check last cable from @warriorpoet ), and if I plan to use a custom adapter (only fiber carbon socket available now), I'd go for carbon fiber.
Yes, you can ask your cable with or without molded ear guides.
Which would you guys choose to go with a gold CCA 12...
or this one...
I agree, quality of wire and plugs is probably similar, so get the one which allows qdc/zsn/C-type plug option.Probably the KZ because the type c connector will sit flush.
For ZSX comfort, you could re-mold the ear guides using a heat gun or hair drier, to achieve your desired position, or even remove them carefully.I am in need of help from this knowledgeable community! So, I just got my ZSX in and im mostly loving it. However im having a cable problem. The gold/silver 8 core upgrade cable ive been using all along with my ZS10 Pro's actually feels really uncomfortable combined with the different shape of the ZSX. With the way the earhooks are molded, it actually forces the ZSX out of the position i found to be the most comfortable in my ears, and decreases the quality of the seal too. At first i thought it was the ZSX themselves, but nope. Its the cable. Ive been thinking of picking up something a little nicer anyway, and here's when i really need the help of this knowledgeable community!
I've been shown these a few times by members on here and am considering getting them
FENGRU DIY JCALLY Gold JC16 6N OFC 16 Shares 480 Cores Earphone Upgrade Cable for Shure SE215 IE80 KZ ZST ZSN ZS10 Pro TFZ TRN
https://s.click.aliexpress.com/e/LCpX0spi but i need to know the dimensions of the plug on it.
The case I'm using to cover my S10+, while providing excellent comfort and protection, has a very narrow channel covering the jack. This has been a major pain in the neck for me since I got into the Chifi hobby. This kz upgrade cable is literally the only one I own that fits!
Ive taken some measurements. The plug on the upgrade cable is 8mm in diameter and 19mm long. And that fits like a glove. I had purchased a TRN T2 16 core cable recently and unfortunately it doesn't fit and i dont feel like paying to send it back to China lol. The plug on that cable is 9mm wide and 16mm long and is too wide and short to fit! That tiny bit of difference made it unusable. So I figured I'd ask if anyone owns this JCALLY cable and happens to know the dimensions of the plug, that would be a big help to me and I'd really appreciate it ! I really don't wanna order another cable I can't use with my phone!
Also if anyone has any other recommendations for nice cables (preferably under $30) that have a plug size that's the same, I'd be interested in checking some others out too.
Thanks in advance!
So just to follow up on this cable.
I am using Alclair Studio 4 IEMs right now, which are not particularly cable-sensitive. For example, a 4 core Forza Audioworks Hybrid and 8 core Gu.Craftsman 6N OCC Copper are sonically indistinguishable, which is unusual- the Forza is typically much more direct, and the Gu.Craftsman is generally noticeably more "reference," clean and extended.
However
For whatever reason the synergy is just there with the ElectroAcousti silver strand cable. Man, it is big, bold, wide and all kinds of spacious. I don't know how to explain the difference, but it is there between the other two very, very good cables and the EA. I can't wait to hear the difference on a set which IS very cable sensitive (Fearless Roland), but for now I'm switching back to the Forza, since the Alclairs are my studio and stage monitors, and a gigantic jewelry grade python isn't exactly subtle.
One other thing about the EA silver strand cable. I've not experienced this with the other EA wire, but I'll be looking for it in the SPC cable arriving tomorrow. Bass impact is less hollow-sounding than the typical BA hit. There's a bloomier decay with the EA cable that's far more DD like than usual. I wouldn't call it a drastic change, but subtleties have a way of adding up to larger differences, and paired with better treble extension, the EA cable just sounds "more" than the others on this normally cable-agnostic set.
Amazing one! True jewelry. I lost the track of your collection.. which wires are these?Just wow.
Glad you got it at last. They are usually taking less than 10 days to Spain (using Aliexpress Standard shipping).Just got my cable: https://www.aliexpress.com/item/4000009633191.html
awesome sound quality, the cable itself is a bit on the soft side(too soft for my taste) and thin ( would want a 8 core version of this, this is 4 core).
The only real bad thing is that the chinslider doesnt work at all, like If you hold the cable up the slider goes down and if you hold the cable upside down the cable goes up. ( I do not use chinsliders so it doesnt matter to me)
Sidenote I asked the seller to change to these plugs instead: https://www.aliexpress.com/item/1000007390678.html (the plugs are the same as the default only the material is metal instead of plastic, judging by the pictures at least)
And these plugs do not fit entirely on my KXXS sadly.( still works but sticks up a bit)
Yay, anxious to know more about this wire. The cable is really pretty. I think I'm going to order it, but I don't know if I should mix the 24k gold electroplated with copper.I am loving the combination of the 24k electroacoustic cable and the LZ A6. The stock cable that comes with the A6 is very good in itself, so I'm not noticing drastic changes with my new cable, other than a blacker background and better ergonomics. The new cable is by far my favorite that I own now and I highly recommend it!
Yes, cable 175 is my favorite, but it depends of synergies: 175 is the most versatile in my list (177 is the second), but might prefer 174 if I pretend to perceive tighter bass, or 171 if paired with very bright IEMs.@hakuzen Bro, is cable 175 still your favourite? Might be interested in buying it since I liked their budget one.
edit: And do you prefer carbon fiber or sandalwood for the connector and "divider" (not sure if its called divider but thats what it is listed as) and what about Rhodium-plated plugs vs normal plugs?
edit2: Can I ask the seller to make the cables with earhooks?
I don't know. It didn't offer any discount on previous AE sales, so I wouldn't expect it to be different on 11/11 (other than AE coupons -not "select" coupons-).@hakuzen Does Electro acousti Store have a sale on 11/11?
If you get a more expensive cable, consider purchasing a MMCX to 2 pins adapter.my cable is 0.78 mm 2 pin so cant lol
