ShabtabQ
- Jul 21, 2016
I tried alot of cables whit tin t2 the best one is ISN S8 for the tin t2
Thanks I was looking at this one
https://s.click.aliexpress.com/e/cNRTwRGM
I'll then buy anyone of these.
Great cable with a very dark background.Thanks I was looking at this one
ISN Audio S8, without any doubt.Can anybody recommend me a 2.5mm balanced cable for my Tin T2, around $30 preferably, maximum $50.
yes, it's 168 (thanks, you are getting used to my crazy cryptic numbers!).Great cable with a very dark background.
It could take the edge off the highs which may at times not be desirable. It's 168? on @hakuzen list i think.
I'm interested to try these.
i've not tried this.
added new acquisition to the list:
175. tw upocc AgAu+copper lizt 8c (silv/cop,eagle,MV).195..163..161..173 mΩ..[35.7g]..141..139 pF..[137cm]
this is a custom cable: 1.5m long (from 12m of wire), mix of cables 170/171 (copper) and 173/174 (silver).
one core of each material is used in every contact/signal. this way, the attributes are a direct average of cables 171 and 174, and i think i's the best approach for mixing different wires in single-ended cables. other possibility to explore with balanced cables is using one material for positive signals and the other for negative signals, which is possible to be made in 4 cores cables.
it's the most versatile cable: it can pair well either with dark or bright combos.
not needed to say this is same top quality cable as 174 and 171. mix of one of the purest copper and silver wires (up-occ) you can find.
curious thing is how the craftman braided the cores; the result is like a zebra snake, very original indeed.
pics: it's a true beauty..
i think i should had ordered a red sandalwood jack this time, and polished 2pins plugs..
other pics of the "snake":
added new acquisition to the list:the
175. tw upocc AgAu+copper lizt 8c (silv/cop,eagle,MV).195..163..161..173 mΩ..[35.7g]..137..138 pF..[137cm]
one core of each material is used in every contact/signal. this way, the attributes are a direct average of cables 171 and 174, and i think i's the best approach for mixing different wires in single-ended cables. other possibility to explore with balanced cables is using one material for positive signals and the other for negative signals, which is possible to be made in 4 cores cables as well.
it's like 171 or 174. expected more stiffness when i first ordered these 8 cables, and found they are suppler than i thought when received them.So it arrived .. and beautiful indeed ..
How is the ergonomics and stifness against other cables ?
it's a custom cable manufactured at electro acousti shop of aliexpress. it's a mix of other stock cables from them, cable 171 and 174 in my list (check the link at my signature: there are measurements, comments, pics and links to these cables inside)Hi there,
What is the name of the cable and where did you buy it?
It's a Beauty.
Grtz
Fer
