SilverEars
- Sep 18, 2013
ZOYI ZT109 meter in da house!
I measured my first two cables. My stock Hidition iem cable's right side was .85_ ohms. I subtracted .1 ohms from .95 because my alligator clips was about .1 ohms.
And then I measured Y*ny** (we cannot name, you should know who I'm talkin about) measured pretty consistant except right negative wire. (R+R-,L+,L-) = (.48, .25, .48, .48) Edit:these measurements aren't precise, and it's probably due to using provided leads.
Edit: This doesn't seem to be that reliable. The resistance is dropping continuously. You need a good clamp on the metal to get a solid reading. How hard you apply the lead changes the resistance. I think what is needed is something that is reliably grasping the metal to make stable measurements. I will have to get those micro clips.
