jamato8
So how is it clearly and objectively superior?
Originally Posted by Dept_of_Alchemy /img/forum/go_quote.gif You guys, seriously, the WA6 even without upgrades costs several hundred dollars more than the MkIV SE. Looking at the components and circuit layout the MkIV SE is clearly and objectively superior, the only thing I don't understand is why had Little Dot skimmed on the stock tube compliments. I'll bet that with several hundred dollar worth of upgrade tubes the MkIV SE will outclass the WA6 by a long way. There is a lot of prejudice coming from the head-fi old timers against Little Dot, mostly as a result of the whole LDII+ fiasco back in the day, but the new Mk series is a good, reliable, high quality product with solid engineering and TOTL component selections that I would recommend to anyone looking for an entry to mid level tube amp. |
