Granted, there is quite a price difference, but wanted to get your opinions on these two tube amps:
1. Little Dot Mk IV SE
2. Woo Audio WA6 (stock)
Apart from looks:
LD Mk IV SE:
- OTL
- upgraded components (from the Mk IV) e.g. Vishay-Dale resistors, ALPS potentiometer, Nichicon, Rubycon, and German WIMA/ERO capacitors
- Neutrik locking headphone jack and American CMC gold plated RCA jacks
- 2x WE408A and 2x E1822CC tubes
- Weight: 7.7 lbs (if it is any indication)
WA6:
- transformer coupled
- stock caps (none of the upgraded ones for budgetary reasons) but has Alps potentiometer and Dale and Vishay resistors
- 1x 5AR4 and 2x 6DE7 tubes
- Weight: 13.5 lbs
Will be used with a few headphones, both low impedance (40-50 ohm) and high impedence (250-300 ohm)
Thanks in advance,
X
Apart from looks:
LD Mk IV SE:
- OTL
WA6:
- Weight: 13.5 lbs
Thanks in advance,
X
