Larry
Thanks for the impressions. I was kind of indecisive about getting a pair of LCD-2 again or HE-500. But are you going to sell your HE-5? I don't know what HE-500 will make me think of my HE-5 but they have been the best of all I have tried and there's something about its beauty and the fact that it has been discontinued which makes me think : I don't think I want to sell these...
But again thank you and I guess I am going to choose HE-500 over LCD-2 with my purchase
I'm keeping all the HiFiMan headphones as a collection, and for reference and comparisons. I love the wood cups on the original, and they still sound wonderful with my ZDT amp (as do my HD800).
I love reading your comparisons HeadphoneAddict! Thank you! I have been wondering how the HE-500 go against the others in the series! Answered pretty much everything for me. \m/
I run my HE-500's through my DACmini and find it quite amazing! Maybe i will consider an amp down the track, but right now im content with my minimal setup.
The DACmini is certainly good enough for these, and later you will appreciate them more when you feed the DAC into a nicer amp. But for 90% of people out there is does everything you need.
thanks this answered a of my questions, I am using the HE-5LE right now more the the LCD2. And I have been asking myself if it's worth upgrading to the HE-500. I am thinking that It's not.
@headphoneaddict. Is there an amp that will work well with both the LCD2 and the HE-5LE? I am looking to upgrade my Glite with DPS; thanks
Well, that's a tough one because these phones have different sound signatures and often work best with different amps.
My ZDT is fantastic with the HE-5 LE but seemed a little dark with the LCD-2. It was still acceptable with the LCD-2, and even better when I tried it with the ALO Audio chain-mail cable on the ZDT at RMAF last fall. The LCD-2 were best with a Sylvania gold-pin 5751 tube, while the HE-5 LE and HD800 were best with a Tung Sol 5751. I'll post soon how it sounds now that I got it back with the partial silver transformer upgrade, and I'll try my Telefunken smooth plate 12AX7 with it as well. It might be just the ticket for a wider assortment of phones, as long as you don't mind swapping out one tube if needed.
As for more affordable amps, the HE-5 LE and LCD-2 both sounded great with the RSA SR-71b balanced at RMAF, but I don't have my balanced silver dragon cable for LCD-2 yet (ordered around 5/26), and single ended the XM5 portable sounds better with LCD-2 than the SR-71b. Balanced it's a whole different story, and you don't need to use a balanced source because it seems that the improvement is in the balanced output (more power and voltage swing).
The WA6 sounds good with both, but underpowered with both if you like to listen very loud, same as with the ALO Amphora. The HE-5 LE are harder for these amps to drive than the LCD-2, but even the LCD-2 seem to benefit from a more powerful amp. Again, I used different tubes with HE-5 LE than LCD-2 but the WA6 sound can change a lot just from changing tubes. Regardless, in this price range for these orthodynamic headphones I think I'd pick the SR-71b with a balanced cable over these WA6 or Amphora.
The EF5 is great with HE-5, HE-5 LE, HE-500 and HE-6 and still pretty good with LCD-2 but not optimal, like with the ZDT. Some tube rolling or opamp rolling could fix the LCD-2 synergy I'm sure. It's got great power reserves for the HE-5 LE and HE-500, so it also has more than enough for the LCD-2 although the LCD-2 might benefit from a slightly brighter tube. This is probably still behind the balanced SR-71b, but a bit ahead of it when the SR-71b is driving the phones single ended.
The DACmini is great with LCD-2 and pretty close with HE-5 LE and HE-500, but the HE-500 is a little better suited for the DACmini than the HE-5 LE because of the improved efficiency (stock gain of 8). It's not lacking power and can play loud, it just give the HE-5 LE the same impact that the EF5 amp offers them. The DACmini is slightly brighter and more airy sounding than the EF5, which suits the more recessed highs of the LCD-2 better; but the EF5 is more powerful and punchier which suits the HiFiMan phones better. Still, the DACmini is still a great "jack of all trades" and enjoyable with just about every headphone I've tried on it. I had similar findings with the Nuforce HDP, except it's not as good with more aggressive phones like HD800 while the DACmini is fine with those.
Personally, I'd want the DACmini as my source + either the EF5 or the SR-71b with balanced output adapter, and use them as a combo to drive both phones according to my mood.
Hey HeadphoneAddict, looking forward to you trying the WA6 w/ the 500s; I'd like to know how well it drives it.
Since the DACport and ALO Amphora can drive the HE-500 I believe the WA6 is going to do just fine. We'll see.
