kugino
- Nov 15, 2003
i don't know what the price is for the sr009 in the UK, but here in the states, with the current strong dollar, the sr009 and the he1000 are about the same price.
Yes, but I mean, since you mentioned copper cable, do you use an aftermarket copper cable or just the stock one?
Since the stock one is a combination of copper and silver, of which I had no idea as well.
If the inverse of what I experienced with the HD650 is true then maybe the HD800 could have some extra bass with a full copper cable.
Will try to have a listen as well when I go to listen to the rest. That "shop" has the HD800 as well as a lot of amp brands so I hope he has a balanced Senn cable as well.
I'm intrigued ...
http://hifilounge.co.uk
Stax 007/009 should be the best for classical. Quite surprised that noone else mentioned those
I don't think that would really have to do with the orientation of the grills. Fang has been tweaking the HE1000 internally since CES.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
I was not implying that it had to do with the grills. I don't know what or how many tweaks Dr. Fan did between the two models . My only comment is that the one at Jude's office according to Jude was better sounding to the one at CES.
yup thats what i figured. just preventitive clarification i guess to prevent grill orientation discussion hahah.
Sort of like the reverse of why I wear vertical stripes... to attenuate my horizontal "tallness!"!
awww cute pix. and i'm guessing your pajama's have horizontal stripes to attenuate your...
heh
Not that hard to outclass a HD800. It has virtually no bass
But for example, a piece like Berlioz Requiem which has a lot of bass and sub bass and is even hard to play on many a decent speaker system, how does the HD800 cope with that?
I like my Hifiman HE-6 better than I did the HD800, and much prefer the HE-6 on most all music, except maybe on classical.
HE-6 has better tactibility, deeper, tighter bass, and is more coherent top to bottom than HD 800, if driven properly.
The HE-6 is also just as detailed and transparent as the HD 800, again, if driven properly, IMHO.
The HD 800 even sounds less engaging, and more "sterile" than the HE-6.
They are both brighter than neutral, but the slight brightness of the HE-6 doesn't bother me like the HD 800 did.
The only thing the HD 800 did better was that it was easier to drive, and the soundstaging was superior, but this was with classical music only.
I like the HE-6 more and more as I listen to them.
They are also clearly superior to the HE-500 in speed, transparency, detail, coherence, and bass tightness.
Only to the bassheads.
You would have to compare the sound in a theatre live to see how much bass is produced with what you want to be produced.
Figaro69 gave a good description above.
The HD800 is the only headphone I own that reproduces the bass subharmonics on a piano the way I hear them in real life, with the correct volume.
I have HD800 & HE6. The HE6 as well has great performance on piano. My wife is classical pianist, she prefers the Hifiman over the HD800 on piano pieces. (driven by EF6)
