jasonb
- Sep 14, 2010
So apparently this thing sucks: https://audiosciencereview.com/foru...asurements-of-hidizs-dac-and-amp-dongle.8707/
Of course it sucks! It objectively sucks.So apparently this thing sucks: https://audiosciencereview.com/foru...asurements-of-hidizs-dac-and-amp-dongle.8707/
What I can understand from that forum replies is that the D firmware was not used, it was tested right out of the box. The user does not believe that the D firmware would make a difference. I guess he just didn't read the instructions.Testsd not using firmware D?
This is an example of pure objectivism. They just don't believe in many things and that impedes them to see the bigger picture and to be the most objective they can be.
After reading the reviewer's reply when asked about firmware used, he basically thinks that his tests showed that the dongle lacks power, so the firmware will not do anything.
On Android, I can definitely hear an increase in volume, power and details after flashing to D, so it's a shame it didn't get tested
That sounds like one of humanity greatest failings.
The reviewer tested it using Windows, which is not the most audio-friendly OS for the intended purpose of the Sonata. Moreover, tested the Sonata without firmware D (or tested it using only the default option, failing to explore the full set of capabilities the Sonata can offer). Also, the comparisons and ranks are made against many DAC that are not at the same functionality and specification levels, including external-powered and/or with dedicated amplification sections. The objective review is an interesting exercise to see how the Sonata can compare, out of the box, with other DAC/AMPs independently of typology and type of usage. It is not a valid review regarding the main intended usage for the Sonata, or more specifically, the audio-oriented use, i.e., to be connected to an Android device, to be set in firmware D, to be locked in bit-perfect mode using an App that allows it.
Other critic that comes to mind is the choice of headphones to verify the sound impressions of the Sonata, which CAN and WILL drive such demanding drivers but, at the limit, SHOULD it? It is reported that the Sonata can drive the HD650 at satisfying levels of sound pressure, but does it justify using it as a main system, when the Senns are from another division in price, sound and power demand? Do the Sonata buyers really want it to drive a pair of 300 Ohm headphones or even orthodynamic headphones, or do they, in contrast, expect it to extract the best they can of some 16, 20. 32, 64 Ohm IEM or portable headphone? Wouldn't a Koss PortaPro be a better fit for a sound impression test?
Also, to avoid confirmation bias, the subjective experience should always be conducted before the objective one. This is to say that you cannot cheat the oscilloscope, so you should first try to listen to music through the Sonata, take impressions, marvel at what it can do for as little money and footprint, and only then take it to the testing apparatus. Doing it otherwise, like the reviewer did, gives the impression that he/she first saw the graphics and then went to listen to the defects that were detected.
