obobskivich
I feel like you can get what you want for less money. Take a look at Ultrasone would be my first suggestion. The HFI-2400 and PRO2900 specifically. Or Denon, the AH-D2000 and AH-D5000. The PRO2900 is probably the most accurate of the bunch, the HFI-2400 probably the best value. None of these run more than $500. You do not need to spend >$1000 for any reason imho.
Amplification for all four of those is fairly minimal in terms of need - FiiO amps will do you fine. I'll leave the computer choice to someone else - let's just say I disagree (oh and if this is financed, disregard all of this advice: do not buy anything until you can actually afford it (and I don't need to hear the sob story)).
