Tweaking was changing pads and protruding driver out of cup. But nothing electrical.
Grado Modders Go Nhoord?!?!
- Thread starter fleasbaby
SHAMuuu
- Sep 23, 2013
did the prices go up?
nhoord red 90 euro
i swear it was lower not too long ago
you cant do warranty? maybe they will help you out to keep a custie
nhoord red 90 euro
Oh yeah, I did put tape over holes in driver to decrease the bass and bring out mids. But I don't know how that could have shorted out the driver.
SHAMuuu
- Sep 23, 2013
I'm not sure, but it is possible...maybe ... ?
Well I'm interested if any engineers in here could possibly explain
I'm sure I did something.
I loved these with Liquid Carbon. The forward mids really complemented it. But having sold the carbon I realized the Nhoords did have some recessed mids and I guess I tried too hard and did something to the driver. My bad.
Oh well.
But on a happier note. Covering the two driver holes did really bring the bass down and bring up the mids.
Oh well.
SHAMuuu
- Sep 23, 2013
I'm sure I did something.![]()
Oh well.
But on a happier note. Covering the two driver holes did really bring the bass down and bring up the mids.![]()
Most of the mods i've done made the headphone sound worse, but ofc i dont always know what im doing, just boredom
I do have some drivers lined up for when i pick up a sr60
or maybe just grab some 3rd party cups from etsy , and those aluminum gimbals, rods from ebay
or just grab a sr60 and call it a day
You're going to put new drivers in the sr60 plastic cups?
Check out the sr60 mods threads on modding them, its a good place to start. I usually install dynamat in the cups, 6-8mm wide strip all around the cup, sorbothane on the back of the driver cut in to smaller sections once it mounted but don't cover the vent holes, and for the sr60, open 2 vent holes on the housing to add a little bass seems to work for me
What improvements do the dynamat and sorpothane have on drivers if I might ask?
I'm assuming it's all about less resonance and dampening.
I'm assuming it's all about less resonance.
The dynamat increases the mass of the cups to reduce the resonance as you noted which really helps in cleaning up the bass and makes it less one note, also gives the impression of a bit more extension since it lowers the mid-bass bloom to me. In addition I like the EZ G pads which gives a slight increase in sound stage and helps to enhance the little sub-bass that is there.
The sorbothane on the back of the driver cleans up the overall sound, not just the bass, had to do some trial and error to find that I liked the effect of the 50 duro better than the 70 duro, both 3/16" thick and cut in to smaller squared after installing a single square on the back of the magnet, got this idea from the Stax and HE-400 threads.
Having done some foster tr50p mods. I could see it benefit on plastic but don't you want some wood resonance? That's the idea for wood isn't?
Is sorbothane same as acoustic foam. I have some acoustic foam left over from my foster modding.
With wood I didn't think the dynamat would make a sense as you noted about the resonance but its also about the density of the wood. Its why I love my TYR Rauna speakers which have boxes made of concrete (very dense and no resonance), heavy as hell but they sound so sweet.
Sorbothane is a vibration damping / controlling rubber:
https://www.amazon.com/Isolate-Sorbothane-Vibration-Damping-Sheet/dp/B004LY8UTY/ref=sr_1_4?ie=UTF8&qid=1480098901&sr=8-4&keywords=sorbothane+sheet
Headcan
nhoord red 90 euro
Looks like Jaco made some changes.
The driver cover is now precision milled from aluminium (previously 3d printed) and sold in matched pairs (like the Ypsilons).
Went back to check the price and I paid 90 euro 2 months ago. Hope someone post what the new revised driver sounds like.
fleasbaby
Member of the Trade: Wabi Sabi Headphones
- Jul 8, 2011
So I have a pair with the new aluminium driver covers. They sound pretty much the same as the ones that had the 3D printed cover to me. Same great sound signature, just a little more weight and a more professional look.
thaddeussmith
- Oct 19, 2009
They're currently 70 euro, which works out to be $76 USD.
