brokenthumb
- Oct 31, 2010
Another vote for L-Cush. Recently put them on my SR80i and the changes Biscuitz said is what I hear also.
What models do the L-Cush pads fit? Will they work on the SR125i and do they provide the same benefits?
L-Cush pads sound great on the SR125i!
Honestly, the entire Prestige Series sounds best with L-Cush pads, in my opinion. I'm not sure why the lower models even come with different pads. Maybe less expensive to produce S-Cush pads?
Another request for a comparison, has anybody compared the MS2 with the PS500 please?
Hey Bill. You recently picked up the SR60i, right? I highly recommend trying the L-Cush pads on your SR60i. It's a simple pad swap, and for $20 I think it substantially improves the sound of the lower model Grados. Things to expect: slightly brighter tonality, better defined vocals, greater imaging, greater separation, greater "air", greater bass definition. It's an investment that I personally consider mandatory for the SR60i.
I've always been a strong advocate for the SR60i w/ L-Cush pads, and I'm reaffirming my advocacy today! I've missed my SR60i, so today I picked up a new pair from the local Grado retailer I listened for a while with the stock pads, and then switched to L-Cush and immediately re-experienced why I advocate for the L-Cush pads so strongly. I still maintain SR60i w/ L-Cush pads is the best value I have yet found in the headphone world.
If the $20 isn't a problem, try it out! Report back with your findings!
Gotcha, thank you man! I will order a pair today, give them a go, and get back to you on this. Currently I am using the yellow AT (?) pads and they are an improvement in comfort over the stock pads.
I've been listening to my HiFiMan HE 500's with a Schiit Lyr. Do you think Grado Rs1i would also be a good pairing for the amp?
I gave my 60's to my dad after getting 325s. He got L Cush pads for them and now I feel like I may have been a tad hasty in getting the 325s after hearing them.
