cel4145
Another congrats. If I could only have one set of my headphones, those would be the ones I would keep. If the Grado sound is right for you, you'll really enjoy them
Thanks...I'll pick one of Grado's adapters and see. It's pretty annoying now as I find if I start moving around a lot....it's touch and go.
With the Grado specific adapter-I had zero problems. Clear connection. No more fadiing in and out sound as the I moved around.
Quick question. I am looking to buy some used either 225i or 325i headphones, but I know there were some earlier models without the i . Is there a way to tell if any given headphone is the older non-i version or the newer improved model. This would be in a photo as I am shopping on-line for the most part. Or would you have to actually have the hp in your hand to tell?
I have a question for the Grado fans. I owned the RS2i before, eventually sold it because the sound especially the treble was too harsh, but I thought the upfront presentation and tonality works for some kind of music. Since then I have been looking forward to trying other Grados, namely the RS1i, PS500 and MS Pro.
Based on the comments I came across so far, it appears that the RS1i and MS Pro are very close to one another, but MS Pro works better for classical while RS1i for most other genre. PS500 would have the smoothest sound and treble easiest on the ear, but a little less detailed and diluted tonality.
Am I mistaken in my impressions, and which do you think would be my best bet.
Thx.
The older SR models (non-i) versions cups are straight on the ends, where as the newer (i) versions cups are mushroomed at the ends.
No. It won't make a significant difference. Most name brand DVD/CD players today have decent digital to analog conversion. You shouldn't need to spend more than $100.
I'd be more worried about the quality of the preamp section in the Pioneer unit you have. When you get the CD player, compare it with everything plugged in through the Pioneer, versus the Asgard plugged directly into the CD player. You may find that Pioneer unit is the weak link. Or it may be OK. But try it.
A question for those of you in wintry climates: have you ever experienced the pads freezing and crumbling? I received a set in the mail today and I noticed the box contained a lot of deteriorated foam particles. The surface of the pads touching the box (and subsequently the coldest) were affected, the rest seemed fine.
