This is a huge minus for me. The GS3000e weight was just right at 330g. About the same as the Sennheiser HD800S which is also praised for its light weight. I chose the GS3000e over the PS2000e for that reason. The hybrid metal cup does two things: makes it heavier, and is a slick way for Grado to use less cocobolo in the cup. The price also increased from $1795 USD to $1995 USD.
I always substract the cable, just for the idea of not carrying its weight with the neck.
The e series 8-core is 76 grams (on kitchen scales while damaged GH2 repair), 12-core 83 (GS1000e modding).
RS1-X (still donāt like the hyphenā¦) 190 grams
Hemp 200 grams
GS3000e 258 grams (Add its 8-core: 334 grams)
PS2000e 460 grams (Yep! Quite usable for selfdefense)
I need to say Iām quite insensitive to a headphones weight. Can wear Audezes or even the HEDD phone all night long. (3 Kids. Donāt try it anymore while ā¦daylight.)
Maybe Iām nearer to Neanderthal man. (In behavior the wife sometimes might agreeā¦)
Of course comfort is essential for headphone listening. Even if one is a 6.6 and 250 lbs Wrestling Proā¦ being able to bare it doesnāt mean one likes it.
And the PS2000e as Audezes and the likes really arenāt designed for females.
For some uncomfortable is the heat accumulation even under open back cups. Not a big thing with Grados in my opinion. To others the itch from foam/textile pads. The sweatiness with leather pads. Driving me nuts is the ear scratching at the diffusers mesh with L-cushion. I mostly prefer L- over F-pads soundwise. A depth of 15 mm is to little to average ears. I do have comparatively small ones. 20 mm is the absolute minimum. 2.2 is good.
Another point is a 6 feet cable. Not portable, not stationaryā¦
(French reviewers sometimes talk about 2.5m cables. Do they have different versions?)
Back to original topic:
I donāt think we have to worry about 500 grams GS3000Xs. Cocobolo is 1.1 grams/cubic centimeter material, aluminium about 2.7. But here weāre talking about a relatively slim inner sleeve of aluminum, not the bigger outer housing. So I guess/hope including cable, which now is 12-core they will be about 360 grams. Steel would be another thing. Itās 7.8.
I see that there isn't a GS2000x. The GS2000e was a terrible headphone, and this is probably Grado's admission that they screwed up with that one. Lastly, there's the GS1000x, which has become a hybrid of two woods: mahogany and ipĆŖ. I hope that goes well better than the GS2000e, which was mahogany/maple.
IpƩ or Lapacho is a wood nearly as dense as Cocobolo, 1 gram/ cubic cm, but has a different structure. Mahogany is .6, Maple .53.
Ignoring the different driver (lighter coil, stronger magnets, lighter diaphragm), Grado this time put the much harder wood to the driver. Compared to PS2000e and GS2000e itās the other way āround.
I am curious!
