Knee Deep In Epoxy
Good summary!That helps alot, thanks. Fun vs Sophistication -- that sounds dangerously close to a pitch for "you need Both!"
Clears make me reflect - Hemps make me smile.
If you can relate, then you need both
With all respect. Try DT 1770 insteadSo let's say I want to go out on a limb and try the Focal Clear. What am I going to hear compared to my PS500e or RS2e?? I've heard several Sennheiser 500+ models and do NOT care for the soft "lush" Sennheiser sound!
(With all due respect, don't reply if you haven't heard the Clear, or if your Grado is lower than a SR325.)
Agree, and they work really well with the HD DAC1 too!Congrats on the Hemps! I too have been somewhat befuddled by the idea that they are a "warm" Grado or the "non Grado sounding Grado". They sound like Grados with more bass and slightly rolled off upper treble. While they sound pretty balanced (more so than many a Grado), I would say that they're definitely on the bright side of neutral, even more so than my Beyerdynamic T1s, which compared to something like my HD600s, are quite tilted up in the higher frequencies. This being said, I LOVE my Hemps. They just make music in the funnest way. I always enjoy them no matter what I'm listening to. So, great first Grado purchase!
Q: How many sets of headphones do you need?That helps alot, thanks. Fun vs Sophistication -- that sounds dangerously close to a pitch for "you need Both!"
A: At least one more than I currently have...
I predict for Reference series will be early October. Since it’s been listed as sold out at 4ourears for awhile now.So the prestige series headphones have advanced to the letter "x", how long does it usually take for the other series to follow suite ?
Just a little overpowered imo - just wish I had more fine control of the volume. You should hear beyer t1s on the HDDAC1 - crazy good.Agree, and they work really well with the HD DAC1 too!
I could sell you that missing link for 6500.-. It`s perfect for your expectations, but it won`t work with lossless FLACs of Scandinavian modal jazz WITH trumpets from the 1970s.
The contortions I'll go through to find the one specific use case that TOTALLY justifies a new purchase.
"DoI have anything for listening to lossless FLACs of Scandinavian modal jazz without any trumpets from the 1970s on my AK70?
Better get these just to be sure."
Which pads are they? They have a few styles.Got a pair of Greekia pads for my GH2 and I am surprised how good they work. It is not only the comfort, it is mainly the sound which makes them a real upgrade. It mellows the highs just enough not to loose any information of sparkling and ping!, puts more body and warmth to the mids and to my surprise, they coax real deep bass out of the GH2. On some of my test-music I was realy scared about this little headphones. Stage seems wider and deeper. For me it was easier to fall into the music and changing back to the original pads the sound was harsh and light.
Think I will keep them.
Agreed! The GH2's really thrive with bass boost on my Pro iCAN.Grado’s and ifi amp/dacs with xbass were made for each other.
I’ve been trying to emulate the xbass effect on the Rme ADI-2 and I can’t.
Love my Hemps.
sr60x and sr80x area almost identical, I can feel midrange and bass area is slight better with 80X though, but not much.
sr125x is a bit different than both headphones above, it's a little leaner and brighter.
