ATTACH]
So you do not have an amp, are you using your phone or a DAP to feed the SR80e? As to the pads you can order a pair of the Grado original flat pads (HP1000) and find the balance change to better suit you. They might likely feel more comfortable once you have properly adjusted the headbad for optimum fit. The flat pad idea is based on an experiment I and a good friend of mine did trying the old style flats on several of the midrange Grados and got some interesting and good results.
I agree with Paraphernalia that considering an inexpensive amp would make a lot of performance sense unless that would be cumbersome in your set up. The one he mentioned is just as he described. The Cavalli HTC that Drop did at least one run already is now priced down to $175, a steal for a tube hybrid that gets a good amount of positive feedback. By chance I did a trade with a buddy for a NecoSoundlab model Portable-V5. It is a dual mono design that can swing 20 volts. I got it for about $100 in trade and it really surprised me how overall very nice it is. Find one and I really think it is another that will make you happy. If you decide to upgrade phones in the future the amp would be a boon to getting the most out of those.
Congrats and Good Luck....
PS I currently own all three of the above mentioned amps although my HTC is the original Cavalli, not the Drop.
Hi! Just bought Grado SR80e, using for about a month now.
Its a better listening experience than my beyerdynamic dt770 pro but I cant listen to it for 2+ hrs straight due to (i think high end/treble fatigue)
Do you think its worth the upgrade to RS2e if I’m just using it with Spotify? No amps or whatsover
I have no plans on buying headphones amp too. Hehe
