johanchandy
- Feb 11, 2011
Ah thanksI don’t think they need more padding, I can use the PS2000e for hours without issues. You just need to bend it a little to distribute the weight evenly.
I've attached a few including some different angles of the headphone
in my opinion they do need more padding but it's depend with your situation, the wooden grado pretty much super light weight so more padding wouldn't make that much a difference in my opinion but with ps1000e, i could easily feel the pressure on top of my head, that's why i change the headband. when i tried gs1000i, that's easily one of the most comfortable headphone i've ever triedSurprising how little headband padding is on Grado's wooden flagship, embarrassing to be honest, I'll be getting an aftermarket headband for sure, probably one from Turbulent labs
True, I've found it pretty comfortable so far but I'm a bit spoilt by how cushiony the hd6xx headband is, will see if this one gives me any issues. May just do the headband upgrade for looks alone, those turbulent labs headbands look mighty sexyin my opinion they do need more padding but it's depend with your situation, the wooden grado pretty much super light weight so more padding wouldn't make that much a difference in my opinion but with ps1000e, i could easily feel the pressure on top of my head, that's why i change the headband. when i tried gs1000i, that's easily one of the most comfortable headphone i've ever tried
if you want my advice, you should change the headband those turbulent headband looks pretty classy, feels great too, your grado going to feel like the price they supposed to beTrue, I've found it pretty comfortable so far but I'm a bit spoilt by how cushiony the hd6xx headband is, will see if this one gives me any issues
I've been eyeing that teal one as well haha! Was wondering if the coffee colour is safer but the teal is calling to me!!!if you want my advice, you should change the headband those turbulent headband looks pretty classy, feels great too, your grado going to feel like the price they supposed to be
https://turbulentlabs.com/shop/
the teal one...teal teal teal
TEAL IT IS!!!!! never doubt yourself! have a bit adventurous in your life
imagine
that combination color on
it's really easy, first you just need to separate the black block from the steel spring by moving/shaking those black block back and forth,once it separated then slide off the original headband, slide in the new headband and then pop those black block in, use a bit glue if you want to make sure they won't fell off. from my memory, they included some kind of instruction when they shipped the headband so yeah it's pretty easyIs it difficult to install? Beautiful pictures, tempting headband...
Wow, needing to use glue to hold it together? That sounds like it's permanently damaged to me.it's really easy, first you just need to separate the black block from the steel spring by moving/shaking those black block back and forth,once it separated then slide off the original headband, slide in the new headband and then pop those black block in, use a bit glue if you want to make sure they won't fell off. from my memory, they included some kind of instruction when they shipped the headband so yeah it's pretty easy
i don't need one, i just pop that one in and it hold but grado use glue in the first place though so...Wow, needing to use glue to hold it together? That sounds like it's permanently damaged to me.
imagine
looks amazing!
looks amazing!
can't wait for your next purchaseI ordered the teal, the XL one! Will post juicy photos when I get it!
