fleasbaby
Member of the Trade: Wabi Sabi Headphones
- Jul 8, 2011
Has anyone removed the drivers from the hemp yet? I want to add an HD800 socket to replace the factory cable. Looks like they use plenty of glue, but also seems like it can be softened with heat!
so far the cable is the only negative about these headphones. I was a bit worried about comfort after reading some Grado criticisms, but it’s largely a non issue.
Best folks for re-cabling Grado's wooden efforts are Moon Audio. The glue usually be picked out slowly with a blade. I believe Grado uses an oven of some sort. I've met very few DIYers/modders who can do it without breaking the drivers.
usually people using heat gun to deal with wooden grado
my advice is stay away from g-pad for your own good once you tried grado with g-pad there's no coming back to the on ear grados in term of comfort
If you try a hair dryer don't let it blow into the face of the driver at all. The heat affects the diaphragm badly. I've only seen hairdryers used on SR-series Grados to pull the sleeves from the outer cups, and then with a hand shielding the face of the driver and the heat focused on the sides.
