elvergun
- Jul 15, 2004
I can't find them on amazon italyAnd really effective.
Thanks, it's very kind of youYou could try these (not sure how soft they are thought):
https://www.amazon.it/elasticizzato-pellicole-protezione-auricolari-cuscinetti/dp/B07BTWP6D6/ref=sr_1_4?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=geekria+cover&qid=1595198176&sr=8-4
or these:
https://www.amazon.it/Geekria-padiglioni-elasticizzato-cuscinetti-auricolari/dp/B07QMCSDTB/ref=sr_1_17?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=Copri-auricolari&qid=1595198454&sr=8-17
https://www.amazon.it/Meijunter-Ela...WS1NK71B8SX&psc=1&refRID=8G44D3XP3WS1NK71B8SX
Try anything that will keep the scratchy pad from touching your skin.
And if everything else fails, you could replace the pads with an aftermarket brand, which are much softer than any of the Grado pads. Before I found those covers I was using Sennheiser 414 pads.
https://www.amazon.it/auricolari-ricambio-orecchio-cuscinetti-riparazione/dp/B0155XZJ4I/ref=sr_1_2?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=cuscinetto+grado&qid=1595198856&s=electronics&sr=1-2
The Sundara is a bit more transparent. Not a huge difference there except in the treble. The Sundara has the best treble of any headphone I've heard. Yes, big compliment but it is true. The Sundara handles treble amazingly well. The tonal mids of the RS2e are its strongest point.do you find the sundara more transparent than the rs2e? and which is more detailed?
I have and like very much the beautifulaudio pads with the lightest and most porous inner foam; GH2 and RS1e sounds amazing and are very comfy.if you wanna go adventurous
https://www.beautifulaudio.biz/grado-earpads-headbands
i have an rs2e, should i take a sundara or not?
It will not replace your RS2e but if you want an alternative it is a great step into planar soundi have an rs2e, should i take a sundara or not?
I'm also thinking about getting a Sundara (but my RS2e is going nowhere...I love it).
From what I've read about the Sundara, it is not as comfortable as the RS2e (itchy earpads aside) and it has major QC problems. If you do go for it, make sure you buy from a place that has an excellent return policy. Be aware that some of those problems can develop after the one month return window, so you better be prepared to send of your headphone to some far away land for service and/or warranty replacement (which lasts one year). Also, you better be prepared to change the pads often since they seem to fall apart with regular frequency.
Grados are built like tanks.
what differences of sound between the sundara and the degree you have?Just some feedback for you.
The Sundara's are WAY more comfortable than any Grado that I have owned. The GH2's are only useable, to me, with Beautiful Audio ear pads.
HiFiman does not have major QC problems. They may have in the past, but people are just magnifying a few problems now. I have owned two pairs of HiFiman (HE4XX's and Sundara's) for about one year in total. The quality was as good as any other brand I have owned, although I did hate the sound of the HE4XX's.
While I am sure a small percentage of people will have problems with any gear, Hifiman is not inferior and does not break/fail regularly.
I can recommend the Beyerdynamic DT 1990 Pro as a great partner for the RS2e (or GH4). Both are equally great, but very different; electronically, physically and sonically.i have an rs2e, should i take a sundara or not?
I read that the Sundara clamps a little too much. Grados are so light and they don't put any pressure on your head. If you can find a solution for the itchy pads, Grado headphones are among the most comfortable headphones you can buy.The Sundara's are WAY more comfortable than any Grado that I have owned. The GH2's are only useable, to me, with Beautiful Audio ear pads.
Yea I have been thinking about adding dt1990. But i'm compulsive about trying new things. I am concerned they may be too bright for my taste. I owned a T1 but sold it after a year.I can recommend the Beyerdynamic DT 1990 Pro as a great partner for the RS2e (or GH4). Both are equally great, but very different; electronically, physically and sonically.
