Shane D
Anyone have any experience with any alternatives
I do have the pads referred to above from Beautiful Audio in New Zealand. Pricey, but SUPER comfortable and don't affect the music, for me.
They come with two sets of "fillers". I use the white foam ones. They do compress after a while, but still sound great to me. There is a mesh one that I didn't care for as it pushed the cups too far from my ears. However when that mesh compresses it might be just the perfect filler.Does it make it better/the same.
The foam is very open and airy...does it take it away???...I can see them as muffling things
@Bonesy Jonesy
did you able to pick or take a look at the wood grain of your gs3000e first? or is it just pure luck? yours really have a beauty looking grain
i'm really curious how many people going to be happy if they got theirs like these one?
if i got one of those... i probably going to ask for replacement...
True...but it’s about selection and...the fading is due to them not finishing and sealing the wood..
Grado certainly thinks it's not a defect. They showcased a light-toned unit at their own CanJam booth.
I noticed no difference in sound. The stock pads on my GH2's hurt my ears on long listening sessions.
Very curious
Is the GH2 same size as the ps1000
Very curious
if you able to notice the differences from this picture... it's more or less like thatVery curious
Oooo I'm getting worried now that mine might change for the worse. I guess not having them directly in front of sunlight by a window and having them in a reasonably stable temperature and humidity room is the way to go. I think you have to treat, handle and care of the wood Grado's like a wood instrument especially when made from a wood like cocobola.that's not mine. and it's come just like that, not the first time i saw that kind of pattern in grado headphones with cocobolo wood
Awesome collection !if you able to notice the differences from this picture... it's more or less like that
(pic source: you know who)
definitely not same
GH2 is much lighter, smaller housing, and use bowl pad as opposed of jumbo pad on PS1000. GH2 has similar size and pad to RS1e.
i think grado cure the wood first before they selling it so the changes wouldn't be that dramatic and from what i understand usually wood aging to darken color so yours should be fine.probably give a bit of wood conditioner/oil from time to time so the wood going to look fresh and shinyOooo I'm getting worried now that mine might change for the worse. I guess not having them directly in front of sunlight by a window and having them in a reasonably stable temperature and humidity room is the way to go. I think you have to treat, handle and care of the wood Grado's like a wood instrument especially when made from a wood like cocobola.
