punkmanmatthew
- Jul 30, 2015
I just want to be sure they r the i version and not the first gs1000 non i
I believe the original had a 4 conductor cable.
Initial impressions?
I at first liked my RS1is better but last night I turned the volume up some more to match what it usually is on the RS1is and the GS1kis sounded pretty good.
I'm not sure if they are more transparent sounding to my ears? They seem to have a little sibilance while the RS1i doesn't seem to really have that but still sounds as clear as the GS1ki or even more so since it's more intimate.
I do notice the big sound stage of the GS1kis. It seems very big. When I switch to the RS1is I have to get used to the sound for a second because it sounds so much more narrow.
I also tried the RS1i pads on the GS1ki for a second and that seemed to sound pretty darn good. I will try that again because I didn't have a lot of time to try that yet.
If I had to choose right now I would say I still like the RS1is but I haven't been able to listened to the GS1kis that much at all so I can't really say.
Maybe it's because the RS1is are more broken in but the GS1kis on first listen didn't sound as "live" to me as the RS1is do but they seem to be sounding more live the more I listen to them.
The person I bought them from said they never used them and got them as a gift and weren't into headphones and they do look it. So I'm guessing they just need some time to break in to my
ears.
I may end up liking them more but I just haven't been able to listen to them that much yet.
