http://www.headphile.com/page7.html
scroll to deal #6
he's out of the middle one, the 325
the rod stops are very nice
Nice, they even come with locking thumb screws!
Very cool site I saved this to my favorites.
Thanks!
![beerchug.gif](http://files.head-fi.org/images/smilies/beerchug.gif)
scroll to deal #6
Thanks!
the thumbscrews is what i was calling rod stops, larry (owner) calls them rod "locks" not blocks, i was confused![]()
Oh I see, I thought you meant the (L/R) rod blocks when you said rod stops.![]()
Totally agree about leaving the 325 alone!
Good info on where to get a Grado headband…I didn't know about this.
I don't have a problem with mods, as long as they're totally reversible.
i partially agree with this. if a mod truly improves on the original design, it can be irreversible.
if it has no improvement (recoloured parts, extra holes in weird places, etc.) then it's best left alone.
the rod stoppers are something Grado should do by default in my opinion, especially on the PS1000.
i'm ok with modding from the 225 on down, the 325, iffy at best, rs and up, i'd leave as is
he does tremendous work
I have a pair of 225i, with bass mod, holes all opened by previous owner and I was looking for an earpad. I plan on eventually getting wood cups to make this my warmer Grado to compliment my 325i with Magnum drivers. I have the L cush currently on my 325 and I like them on my 225, they sound great, however I am wondering about the G cush and how those would sound, I've read a lot on reducing bass and treble. What can I expect from the G cush. Also are the Earzonk G cush, just as good as the Grado? The earzonk are much cheaper. Any thoughts are appreciated I just wanted impressions based on the fact the my 225i have the bass mod to them.
Thanks,
James
Is the bass too heavy/bloated with all of the holes punched on the 225i and do you feel the need to reduce the amount of bass?
I've tried the Grado (G) cushions on my 80i/325is/RS1i (all un-modded) and didn't care for them, I much preferred the Grado (L) cushions with all of these HP's. The only Grado HP I like much better with (G) cushions that comes "stock" with (L) cushions is the GH-1…and of course the PS1Kx.
Although I've never heard the EZ (G) cushions, from what I understand they use different foam (more dense) than the Grados cushions and are apparently one piece of foam, where as the Grados are made from 3-layers of foam.
I personally would buy the Grados.
They are not too bass heavy with the l Cush. Just warmer. 325i is brighter, which I am used to and like a lot. I just wanted to know considering the direction I am taking the 225i, with potentially having wood cups in the future, if the g Cush would be good. if I understand correctly the 325 stock has a little more bass than the 225, and is also brighter. Seems like the bass mod brought up the bass to a 325 level and kept the highs the same. Hopefully wood cups will warm them up a rad more and be a good change of pace from the 325.
It looks like he does real nice work, thanks again for the information.
I meant I wouldn't change out the aluminum cups on the 325. I'm really not into modding the sound-signature of a HP, but if its totally reversible like you said, that I wouldn't mind.
