kvtaco17
- Mar 29, 2013
If your a (HOT WOMEN) then I'l buy something from you…if not ,forget it!
Things can be arranged lol
How bout the Glenn OTL....is it for sale
Still, I'd rather liberate the drivers from the 225 than from the more expensive 325, if I'm going to place them in wooden cups, know what I mean?
You're making me doubt myself... Regardless, the 325 is a good bit heavier than the 225, but has the same drivers and cable. The 125 is lighter still and, if the weight comparison above is correct, weighs the same as the 80 but has better sound.
Personally, I would never put wooden cups on the 325's, I'd just buy the 225's or the 80's in that case. As far as the 325/225 having the same cables/drivers…I'm not sure about the (e) series, but the (i) series have a different cable and the drivers frequency response is different (as far as I remember) so I would check the spec differences between the 2 on the (e) series, unless your positive about this.
stacker45, thanks for identifying a specific comparison test... I had a great time comparing my HP1000 and PS1000.
I used just one song from Eric Clapton's Unplugged , which was "Before You Accuse Me," which I also understand is used by Grado as one of three songs they test their headphones with. My recording is a lossless CD, as I don't have the record in vinyl or reel-to-reel tape (though I do have both types of players). It was played at 44,100 16-bit samples/sec (standard CD, but sold by HDTracks as part of their catalog which includes a lot of high resolution recordings, up to 192,000 24-bit samples/sec! This, however, was the best they had of this song).
By the way, AAC is "Advanced Audio Coding," which uses a variable bit rate of 256,000 bits/sec. It is what standard iTunes uses. Hence, we can compare the coding method bit rates as:
- Apple iTunes AAC - 256kb/sec - requires removal of bits of information from an original CD copy to get to this low bit rate
- Lossless CD - 1,411 kb/sec, or 5.5 times higher bit rate than AAC
- High Definition - 9,216 kb/sec, or 36 times higher bit rate than AAC
- Analog (what you have) - true analog has an infinite number of levels and would really require an infinite number of kb/sec to describe
Somewhere along the line, human perception becomes unable to distinguish among various bit rates, so going higher makes no difference.
So I have listened back and forth between both headphones, both driven by my Joseph Grado HPA-1 amp which is driven by my FiiO X3 running that song from Eric Clapton Unplugged at full CD resolution, for the past hour or so.
What I found:
- There is clearly a difference between the HP1000 HP1 and the PS1000;
- In the bass, the HP1000 HP1 is clear and precise, as it is through all frequencies. The PS1000 is boomier in the bass, which to me makes it a bit harder to determine the pitch of a bass line (sort of like an echo in a barrel... I by no means intend this as a negative, but it does seem to make adjacent low notes sound more similar in pitch). As a result, the PS1000 sounds more bassy;
- In the treble, the HP1000 is very slightly muted or veiled, as if playing through speakers with the cloth in front of them. The PS1000 is more transparent, as if the speaker cloth was removed. Hence, the PS1000 gives you more of the feeling that you are in the room with the musicians;
- In the mids, for example for the singing, the two to me sound the same;
- As regard to sound stage, the PS1000s sound as if they have just a bit more... music comes from a wider angle around you.
I, like you, have the TTVJ flats on my HP1000, and I have the standard Grado G-CUSH over-ear bowls on my PS1000, just as they are sold.
I think we are finding the same thing, if what you mean as "treble extension" is the same as what I call "transparency" or "lack of a cloth veil." It's my own ignorance that I do not really know what "treble extension" means nor what to listen for to determine it. I did NOT really read your comparison of the two before making my own comparison... once I saw that we both had essentially the same amp and source material, I immediately started to compare. To now find that we are hearing the same differences is encouraging!
I would add that the comfort factor of the over-ear pads of the PS1000 is significantly greater than the on-ear HP1000. I am not one to change pads from what was designed by Grado, so I would no more put G-CUSH pad on the HP1000, even to gain comfort, as I would put the TTVJ flats on the PS1000s.
While I enjoy listening with the PS1000 more than with the HP1000, I don't really think the HP1000 is overrated. In its day (1990), it was a $595 headphone (that is for the HP1 that I have, with the polarity switches... the HP2 was $495). With inflation from 1990, that makes it about a $990 headphone today, less than today's $1,695 price on the PS1000 (of course, because of the age, classic nature, and status as the start of the Grado line, you will pay 2 to 4 times that $1,000 now to get one!!! That's OK!)
I think that the HP1000 is the brutally honest friend that tells me I am too fat (so I believe when that friend says I am intelligent). The PS1000 is the much more pleasant friend that dotes on everything I do and praises my manly physique!! Again, I prefer the PS1000 (dessert), but I appreciate and need the HP1000 (vegetables!).
Or, graphically....
O2OAssasin, the drivers and cable are the same on the 225 and 325? OK, I need to think about the direction I am going to go.
My 325is are much lighter with the cocobolo cups. My wallet is much lighter as well.
I'm pretty sure the 125e has the same cable as the 325e / 225e ... the 125i certainly has the thicker cable.
Don't forget the 225e has metal grilles on the earcups, which makes them heavier (although I'd be surprised if it made 55g difference ...)
They are beautiful, how did the rewiring and cupping impact the SQ?
