kvtaco17
- Mar 29, 2013
In what way?
Bro discount and sexual favors... I need this stuff gone... Takes up space I need for more new stuff.
In what way?
I have the 325 and the 60. If you're wearing them while moving around the house, I suggest you consider the weight difference between the 225e (plastic cups) and the 325e (aluminium cups). The 325e are quite a bit heavier than the 225e. In fact, the metal cup Grados are heavier than both the plastic and the wooden cupped (Reference Series) Grados.
If you get the 225e you still have the balanced drivers and thick cable of the 325, but none of its weight. You'll get the L-cushions 'bowls', which hold the headphone better against your head than the S-cushion 'comfies'. They're the same size as the 60, so you can easily take them along to wherever you go. The 325 has a better headband (leather, instead of vinyl), but there are aftermarket leather headbands for sale that are better than the Grado leather band.
340 | 280 | 225 | 225 |
OK, Grado Noob question, pardon me. Do you put the wooden Cups over the existing Cups, or do you replace the metal/plastic with new woodies? The later sounds like it would be quite difficult. How does adding wood impact the sonics? While I am still a Noob, what pads do you guys use with the 325/225, the ones it comes with, TTVJ's Flats, Sennies....? Thanks again for your advice, it is appreciated!
Happy New Year!!!!
Grado 325e Grado 225e grado 125e grado 80e
340
280
225
225
about the weight. the 225e is considerably heavier than the 80e and the 60e.
When the e came out, i auditioned the 225e and 80e, it's heavier.
i dont know about the i series because i only have the 60i and never tried the others (well, 325i,,,), but on the E, the 225e is heavier than the 60e and 80e.
i tried 60e, had it for couple days, and then get 80e. at the same time tried 225e at the store..
You take the drivers from the plastic cup and place them in a wooden cup similar to the wooden cups of the Reference Series.
Not that difficult: the plastic casings are 'hot-glued' together, so warming the glue with a hair dryer is enough to pull the cups apart with your hands.
Wood adds a warmer, often more detailed sound than the plastics. People also woody the 325, but I think that's a waste, as the main difference between the 225 and the 325 is the fact that the latter have metal cups and a leather headband. Drivers and cable are the same. Which is why I said that it's psychologically easier to replace plastic cups with wooden cups, than replacing metal cups with wooden cups.
I change the earpads around. I have TTVJ flats and G-cushions coming (that I want to try on the 325iS after modding them with distancers), I use quartermodded Senn414 pads with the 60. The SennJazzGrado has Grado L-Cushions until I get the EarZonk G-cushions in January. A lot relies on preference. Most people do quartermod their Senn414 and Grado S-cushions.
The extra weight is the thicker cable of the 225, which is the same cable as the 325. The 125 has the same cable as the 60/80.
Minus cable, the 60/80/125/225 all weigh the same.
didnt try the 125e so maybe others can comment on that. but 225e is certainly weightier than 80e. maybe the cable, maybe the metal grill...
also... does it look exactly the same? i remember the 225e to be a bit bigger than the 80e when i tried it. as if the driver seems a bit heavier. though maybe it's memory bias, due to seeing one with l cushion and the other with s cush, and the weight.
I've just got a 225e myself, and it's exactly the same size as all the other Prestige-line Grado's I've owned (MS1i / 125i / 225i / 325i)
Edit to say the only physical difference I can see between the 225e and the 225i are the 'e' on the button, the red paint on the magnet plate and the two holes vented at the rear of the driver.
compare to 80e i mean...
As I said, it's the same size / shape as the MS1i, 125i, 225i I previously owned. I've tried an 80i in a store and that was the same size as well.
Tried the G-Cushions on the SR325is and I think the drivers are too near my ears, making the sound too harsh. How do you mod the "distancers"?
I'm pretty sure the 125e has the same cable as the 325e / 225e ... the 125i certainly has the thicker cable.
Don't forget the 225e has metal grilles on the earcups, which makes them heavier (although I'd be surprised if it made 55g difference ...)
Depends on which wooden cups he is talking about. With the Vibro wooden cups, the driver need to also be liberated, so the plastic around the driver once separated from the cup has to be removed also to fit in the Vibro wooden cups. If he went with Martin Custom Audio for example, he has a choice between full jacket (liberated) slip on cups (non-liberated) but in either case the cups/drivers have to be separated, which is no big deal..and for that matter, neither is liberating the drivers.
Are you sure? I'll get a 125e in January, so I'll be able to compare them with the 60.
