- Dec 18, 2007
@Bidn, great post, and a lot of good points. Thanks.
I can't believe how much bass there is for a single ba. I haven't listened to my ii's in a while but from memory the ii's are more neutral then the iii's more detail it seems. But the iii's are more fun sounding to me. I like them actually. They won't replace my fostex te100 's or anything like that lol but for the price you can't go wrong.I did an a/b between my original drop Heaven III and my new pair. The new pair is noticeably brighter. It doesn't sound like a different earphone, just careful listening of a trained ear would be able to hear the difference easily.. Either the tuning has been tweaked, there is sample variation, or burn-in may apply to this earphone. Both are fantastic, but I prefer the brighter pair. Mids and bass seem comparable between the two earphones.
For those who own the FI-BA-SS, if you haven't tried the JVC Spiral Dot tips, I would recommend checking them out. I've found these are better, especially in the bass, compared to the Final tips.
i don't know if you've ever used custom tips, but how comfortable are these compared to customs?
Hey all, I ordered the FAD Heaven III from the first massdrop run I absolutely love it. Only thing I would change is the cable, its microphonic as hell.. How would I go about disassembling the casing to unsolder the wires and put in a new cable?
I was listening to it today and I'm actually shocked how good it sounds for the money. But as some people have stated before when turning the volume up high they become shouty. But again that's pretty loud to start with. The rolled off treble might be a problem for some but I really don't mind it. And at the cheap cost of these I can't complain at all. I was reading on massdrop today in the mystery box drop they had a while ago some people had got the iv's and they say that the bass is pretty much rolled off. So I'm thinking even though the iii might have the iv driver in them they aren't tuned like the iv's at all from what I have read. Cause if one thing I find the bass isn't rolled off at all really.Hey all, I ordered the FAD Heaven III from the first massdrop run I absolutely love it. Only thing I would change is the cable, its microphonic as hell.. How would I go about disassembling the casing to unsolder the wires and put in a new cable?
Try using them upside down an run the cable back over the ear
While that does work its not ideal, the way the iem is designed is to sit in the ear with the rectangular plastic touching the inside of the ear. A regular cable would allow that and not be as annoying as a flat cable. TY for the suggestion though!
Is final audio heaven vi better than hifiman re600 v2? What's different?
