Pharmaboy
Like you, I needed a balanced cable for my D8000. But there was no way I would spend what Final wanted for an XLR cable that was too short and made of silver (absolutely not something I want for this particular headphone)--so I set out to find a way around the locking jacks thing.That's what I've been hearing, @Slim1970. I've been using single ended RCAs into my Woo 5-LE first gen for years, and with a fully balanced DAC and a good deal on a second hand GS-X mk2 I've decided to make steps down the balanced route. Of course, getting nice XLR cables inbound to the Headamp has only highlighted that I can only really fully utilise the balanced topology if I address the D8000 Pro feed. Creating a rod for one's own back as I don't see so many used XLR cables with the locking pins floating around...but I'll be patient as I believe it should be worth it!
Great to hear you had positive impressions from the combo, particularly given your extensive gear experience![]()
I ended up getting a pair of cable "pigtails" from ForzaAudioWorks, from whom I previously bought 2 balanced cables (their TOTL copper cable, Noir HCP MK2). Matt made me 2 ~6" lengths of that same copper cable with a male mini-XLR jack on one end and a long-shaft 3.5mm male jack on the other. Each of those 3.5mm jacks gets pushed into the D8000's earcup receptacles. They don't lock, but they are thin enough to go right past the interior locking rings, and they don't fall out.
Problem solved.
Before working with FAW on this, I tried to get the same thing from Norne Audio (I have a balanced examples of their terrific TOTL copper cable, the Drausk), but couldn't reach Trevor. He's a one-man show and was too busy.
