It is really pretty easy to replace the pads. I had the same question earlier in this thread and there is a reply with a different video, for the D8000. I didn't book mark it sorry, but should be easy to find.
thanks! let me search for it.It is really pretty easy to replace the pads. I had the same question earlier in this thread and there is a reply with a different video, for the D8000. I didn't book mark it, sorry. but should be easy to find.
Thanks! found it! Most reassuring.It is really pretty easy to replace the pads. I had the same question earlier in this thread and there is a reply with a different video, for the D8000. I didn't book mark it, sorry. but should be easy to find.
I didn't care for the stock D8000 pads at all and changed them to the D8000 Pro's "G" pads as soon as possible. The G pads aren't cheap, but they feel better on my face and definitely sound better IMO.Hi all! I have a D8000 whose ear pads have sadly lost its shape and is a bit flat. Is it easy to change the ear pads yourself? I tried to find any info online and it all seems to point back to the same video on YouTube on changing ear pads for Sonorous. Thanks!
Of course. My bad for not mentioning It.Take note that Phobos are way cheaper than D8000 Pro. Build quality of Phobos for me are it's biggest downside.
….where did you find the video? .... I tried to look for it, but I did not find anything ... you can kindly report it ... thanksThanks! found it! Most reassuring.
https://www.head-fi.org/threads/final-audio-d8000-planar-magnetic-headphone.845567/post-16702880….where did you find the video? .... I tried to look for it, but I did not find anything ... you can kindly report it ... thanks
No worries at all! Good luck! I will be trying to put in on myself when I get the ear pads sent to me.Thanks so much
I've been pairing mine with the Woo Audio WA8 this afternoon and like the results greatly. Very punchy. I was thinking SS would be the way to go, but actually it can sometimes render them too dry. Some tube aspect seems to create a slightly more dynamic presentation without losing too much detail.Hi guys. Im considering getting a tube amp for my Finals. Any recommendations for a good hybrid tube amp for the Final D8K Pro under 1k? Thanks!
Thanks for the feedback. I think that you are totally right, the Finals got more than enough detail to sacrifice a little bit in exchange for some tube warmth.I've been pairing mine with the Woo Audio WA8 this afternoon and like the results greatly. Very punchy. I was thinking SS would be the way to go, but actually it can sometimes render them too dry. Some tube aspect seems to create a slightly more dynamic presentation without losing too much detail.
