gohanssjn
- Jan 28, 2005
Five and a half?
Awesome
Also, I was thinking of doing SPDIF instead of USB for 24/192, but my card only outputs SPDIF in 24/96. Welp, USB it is!
Five and a half?
What's the Bass Boost Levels on the E17?
I know the E10 adds + 3dB of Bass with BB on.
Awesome
Unless you have IEMs you shouldn't have a problem.
IEMs are more sensitive to hiss. I think.
Someone knows more about this than me. ClieOS?
Didnt spdif bypass most chips and thus can do 24/192 straight out?
Unless you are using custom IEM with very low impedance and very high sensitivity, most IEM will hear no hiss with E17. Even with Shure SE530, the most hiss prone universal IEM you can have, it is totally hiss-less in 0dB gain in any volume, slight hissing pass 55/60 in 6dB gain and a bit more hissing pass 45/60 in 12dB gain. However, both 55/60 @ 6dB gain and 45/60 @ 12dB gain are insanely loud for SE530. At most, you are not like to go pass 30/60 for SE530 unless you are already half deaf. So as far as hissing on E17 is concerned, I'll say it is close to a nil issue.
It depends on implementation of the SPDIF transmitter, but most SPDIF chips these day should support 24/192. Do note you need to enable the 24/192 option in your audio property as Windows has them disable by default.
What's the deal with not doing 24/192 over usb? Surely there's enough bandwidth for it?
bowei and cleo: will the e17 have any effect on the battery life of the ipod if used as an amp?
It is not about bandwidth, but the USB receiver. Any USB receiver than does 24/192 usually tends to be very expensive and difficult to implement. But fear not, in engineering stand point 96kHz is arguably the easiest and best sampling rate around for most hardware. Pushing it to 192kHz doesn't always get you better result.
premium cable from Monoprice.
I've never heard this before.
it's called a premium cable. i didn't mean it was. it had thicker stuff on it so it wouldn't bend and was astehtically better than the others. Really just it. it was also cheap. why not. nobody in this range states what MHz it is or how thick the fiber inside actually is anyway so it's hard to even compare at all :/ espeically wehn i want to keep it cheap.
