beaver316
- Nov 24, 2011
Just as i post my last post it finished charging Need some time to test the sound difference between my laptop and the E17 though.
Is denon d2k headphone better than Brainwavz HM5 or Sennheiser HD series?
Another noob question here
I read that it's good to run down the battery of the E17 every once in a while to keep the battery in good shape since im going to be using this thing only on my PC (usb). So if i have it plugged on my pc and have "USB CHG" off in settings, that means the battery is being used? Or is the power coming from my PC?
Got mine tracking and will be here on Friday!! Question that is indirectly related.
One aspect that I'm excited about it being able to use the e17 with my ipod or iphone and be portable. Questions:
1. Is all that I need an LOD for connection?
2. Much of my cd collection is now ripped to flac. Now I want to re-rip and get the best quality for the ipod. Is apple lossless the best?
thanks...
power
thanks...
The battery life on the Alpen is no joke. I have been using it since i got it on April 17th, and i still have not had to charge it!
[size=medium]Really?[/size]
[size=medium]How many hrs usage?? I do not get more than 8hrs iphone->L9->E17->TF10[/size]
iPhone 4>L9>E17>ATH-M50 and Asus G53sx laptop>USB>E17(charge set to off)>ATH-M50. My total run time, according to the system menu, says i have 3days 2 hours and 57 minutes of use on it. I use my Alpen probably 65% laptop and 35% iphone 4, and i am actually surprised at how long the battery has lasted for. I am looking at the battery bar and i still have 3 bars of charge left! I dont leave my Alpen plugged in to my computer when not in use, so i have no clue why that batter is lasting to long! There is no doubt i have used my Alpen for over 8 hours and battery is still strong.
Yes all you need is a LOD. If you use a mini to mini cable you will be double amping which is frowned upon.
No need to re-rip. Just use DBpoweramp or something similar and convert to ALAC. There is no loss in quality when converting lossless files to another lossless format.
Keep in mind the DAC in the E17 will not bypass the DAC in the ipod so it will be an amp only with the ipod.
I like ALAC and can't tell the difference between it and FLAC.
So I will be stuck with the ipod dac no matter what? Well, ipod has a decent dac though right?
