punia
- Aug 18, 2010
Hi All! I own Etymotic Hf2 and really happy about their sound. It's really detailed and analytical – thats exactly what I like.
The only thing I can complain is the lack of bass. I use eq (slightly) in iTunes on my Macbook Pro to improve it. I've just started to read head-fi forums and discovered a lots of yummy stuff
. I'm wondering if there is any point to upgrade to following earphones with Dual Armature (they all in the same price range that I can afford):
1. UE-700
2. Q-Jays
3. Fischer Audio - DBA-02
As I understand they all priced around $150 - $170.
Is it improve my listening quality?
Does it worth the money?
Maybe I should spend same money on some amp instead?
Thanks!
1. UE-700
2. Q-Jays
Thanks!
