proedros
athena owners , share your favorite dap please
I don't fine the U12 (I have Universals) to be slow. More relaxed. Slow makes me think of flabby, which doesn't apply to any part of the U12. It's quite tight, controlled, and agile. But it doesn't have the energy of something with more treble. It's an easy listen, which is where so much of my love for them comes from. It's like the LCD-2 in that way.
But yes, it does have A LOT of bass.
guys, do u all experience channel imbalance, i have used my spartan iv w/o adel customs for 1 week, seems like the left monitor is softer. hence i used the balance function on x3ii and switched it 1 step to the left. and it sounds better. i wonder if it is placebo or is the music recorded in such a way? anyone care to shed some light on this?
Sometimes we used words that do not mean the same to everybody
When I said slow I was trying to explain that IMHO the quantity of bass in A12 dirty some songs.
For example I usually make my tests listening "Bubbles" by Yoshi Horikawa.
This is a great song to test the relation between detail and bass in headphones or IEMs.
With the A12 you get details in the mids and the highs but you need a very controlled and fast bass to avoid dirty the song.
And in this song the A10 do a better job that A12, but not at the level of the impressive ZEUS XR.
But of course it is just my opinion
It does not mean that A12 or A10 are bad IEMs.
Is the quantity of bass in Zeus XR kinda low?
I find that U12 with G1 module to be the absolute minimum bass I require. B1 module is too bass light for me.
If you consider U12 + G1 as baseline, then yes, Zeus's bass is considerably low. U10's bass is lower than U12's bass. And Zeus's bass is lower than U10's bass.
XR (not adel) is fantastic low end. Responds well to mild EQ without distorting, it's amazing. Idk about adel, but I imagine it lighter bass due to how it works
(I am secretly happy for my wallet)
That sounds so painful. I need my bass to feel my music.
Cable will always help.
I actually decided not to use anything other than ADEL for the sake of my ears. I once went wild with JH Rosie and my ears rang until I put U12 back on and listened to some music.
