I've used this, works fine. Small and compact
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
Has anyone found a good type C USB cables to do digital out from Dx200 into a transport for desktop DAC ?
Yes, get this one. It's fantastic...
https://www.amazon.com/gp/product/B01A6F3WHG/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
meomap
So I'm understanding from this thread that Focal Elear and DX200 might be a perfect match for open backed headphones. Opinions?
Even Utopia with DX200 are already very good.
Just acquired my 1st dap, the dx200 few days back. Now in the market for a good iem to match up .
Looking about the it03 , t20i & P1 range , this would be using thru balanced out on amp1 for now.
All comments and recommendations welcome , tia
***listen to mostly pop & Latin songs & music
Lurker0
Speaking about Type-C OTG accessories. I have a number of MicroUSB accessories (cables, hubs) that I use with DX90, DX80 and Android tablet, and found out that they all work with DX200 via a cheap MicroUSB female to Type-C adapter. So, if you have some like me, such an adapter is worth to buy. I ended up with cables and chargers from Tronsmart (for both MicroUSB and Type-C):
http://www.tronsmart.com/products/type-c-adapters
http://www.tronsmart.com/products/type-c-cables
http://www.tronsmart.com/products/wall-chargers
They all available off eBay and other online stores with free shipping worldwide. Their charging/data cables with 19AWG power wires are great for fast charging! But I don't recommend cables longer than 1m for data transfer: DX200 has a "switch" inside between SoC and XMOS, which makes DX200 very sensitive to signal level. Same with DX80.
Note: Tronsmart Braided Nylon Type-C cable looks similar to stock iBasso cable, but iBasso cable is softer and feels better.
I have elear and like the combo. Using with the original cable called the snakeSo I'm understanding from this thread that Focal Elear and DX200 might be a perfect match for open backed headphones. Opinions?
Volume around 120-130. I'm waiting for a black widow balanced to try in this configuration
Glasha
I'm not so sure about this combination because I think that the amp modules have some problems driving the Elear (imho). I will try to use the DX200 with an external amp and the Elear in a few weeks and I will write my conclusions.So I'm understanding from this thread that Focal Elear and DX200 might be a perfect match for open backed headphones. Opinions?
Wait for the IT04 maybe, coming out in a month I guess.Just acquired my 1st dap, the dx200 few days back. Now in the market for a good iem to match up .
All comments and recommendations welcome , ta
Hi Joe, and welcome!
Of the IEM's you've mentioned, I only know the IT03 (and its forthcoming big brother the IT04).
So I cannot comment on the other ones. However, the IT03 sounds superb as posted previously, especially with an upgrade to one of iBasso's balanced cables. IT04 even better although we're still waiting to find out exactly it will be released.
However, for a more, ahem, 'balanced' set of suggestions, perhaps you could let us know what kind of budget range you're willing to consider and whether there's any particular sound signature aspects that are especially important to you etc?
- Oct 14, 2013
Good to know, thank you! I will try and see what I can do with this type C cable thing
There is one thing that I noticed, using Mango player. In both modes, Bluetooth or wired connection, and without turning on the EQ option, the USB-bass is emphasized. I only turned it on for better and more balanced sound, and is not using or sliding any bars.
Morimoriya 62
Hi guys
I have an issue ,I do not know how many percent drive my HD800S with DX200 (amp1,2.5).
Simple say ,some track everything okey ,but sometimes not .
I used at volume 110 ~120 Music related(high gain) .sound very good enough bass impact and slam while some track lack power It feels .
Does anyone same experience like me?
I hope Amp3 Solve the problem
- Aug 15, 2011
I've received my Amp3 today (Thank you @Paul - iBasso)!!
I use my DX200 AMP 2 with an external C&C BH Amp or the Tralucent T1 Amp and it's fantastic. I use my Tralucent 1Plus2 rev 1's, Heir 4a's, and UE900's for IEMs and Senn 650's and LCD 2's for cans. The additional amp seriously brings out the WOW factor. (I go from SE to Bal with the 1Plus2's, the 650's, and the LCD 2's...back and forth)
Morimoriya 62
What do you find Amp3 ? In your opinion which modules warmer than the other .
JacquesDewitt
Hello, has anyone had problems with the sound of pop, crac to start playback or change the sampling frequency?
With T5p is a small sound, tolerable but by switching to the hd800s, the sound is quite strong, annoying, and hurts me a little ear. Is it a defect?
With chord mojo, have not experienced anything, only a small sound by changing the frequency of sampling in songs, so ruled out the hd800s are damaged.
can someone support your experience with amp1 and hd800s?
and another doubt, these sounds of pop, crack have possibility to damage the headphone ? Perhaps you think I'm exaggerating, but I think it is a very strong sound, considering that I hear from 30-40 for hd800s and 10-20 in t5p
Best regards
Best regards
tuckers
- Jun 30, 2004
I've not had problems with this.
Best regards
Total: 14 (members: 0, guests: 14)
