DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
post-13321451
Post #4,981 of 21,843
jamato8
  Currently using FW1.3.60, but I'm downloading FW2.0.7beta. Am I right in thinking that the screen responsiveness issue was fixed in this release?
Also this download seems to be painfully slow considering I'm using fibre. currently getting 60kb/s
I have high speed internet but it varies on the download  their site from what I have experienced over the past. The screen goes back to what it was like in 1.3.6 vs the FW just prior to the beta, which had a decreased response. I haven't had any issues with the beta and it installed without issue using a card.
post-13321462
Post #4,982 of 21,843
pfurey89
So... anyone getting EQ to work / show up inside the Spotify app? Why is it missing?
post-13321526
Post #4,983 of 21,843
Tony1110
Are you using the drop down screen that you pull down from the top to change the setting on the DX200? In Mango you can go to USB Settings.
The bit that asks you to select between charge, reader and USB DAC?
Edit: sorted. It was a problem on my computer's side and not the DX200.
post-13321653
Post #4,984 of 21,843
When folks are burning in the DX200 and not listening, are you using your earphones or the burn in dongle? I've got probably say 240 hrs burn in of which most of that is with the burn in dongle. I'm hearing somewhat grittiness in the trebles compared to the WM1Z with the 1Plus2.2. So I'm wondering if I've wasted the past 1.5 weeks burning in using the dongle and have to restart with an earphone?
post-13321747
Post #4,985 of 21,843
doofalb
No i have enough room on the internal memory at the moment. I just tried to update by installing the .ota file into downloads folder but when i press manual update it just has screen with sd card written on it. Cant seem to direct it to look in download folder.
the zip file has to be in the root folder (no matter sd card or default), so you would have to move it there and then the manual update will recognize it. Also, and maybe I'm the only who got confused: for the manual update the "SD card" is the internal memory and the external SD card is "default"
post-13321818
Post #4,986 of 21,843
javahut
Is it possible to run PowerAmp player on the DX200?
Anyone care to comment on how they think the DX200 sound quality would compare to my current set up... a Galaxy Note2 digital out into Ray Samuels Audio Predator DAC/amp?
post-13322045
Post #4,987 of 21,843
ExpatinJapan
Hell
Hell
I posted my review 6 days ago it says.
Feels like a few weeks already.
I cover connecting to a computer, usatong the firmware and a few other things later in the review.
Could be helpful for some.
I need to update it again after a few more firmware updates.
Also it has a link to the manual download.
http://www.head-fi.org/products/ibasso-audio-dx200-reference-dap/reviews/18124
post-13322125
Post #4,988 of 21,843
artpiggo
Bangkok, Thailand
Bangkok, Thailand
Quick Verification. Is the bass tighten compared to out of the box. Do you feel the echo of bass that leaks thru vocal frequency has disappeared from the first minute of usage?
If yes, I think the burn in cable and period is fine. Otherwise, Burn-in cable could be broken wiring.
Else, is it because the bug on android that sometimes the song stop playing by itself out of blue and make you think it is already fully-burn-in.
post-13322135
Post #4,989 of 21,843
artpiggo
Bangkok, Thailand
Bangkok, Thailand
It can be installed. However, despite the fact that poweramp has nice UI and functionality to adjust sound. I recommend you stay with Stock ibasso music app to get most pure sound as ibasso design it to be. Also, third party app doesn't support Native sampling rate. They are all fixed at 44.1kHz output.
Second question, I don't about that DAC quality. But I have used Letv Max for a long time and can find this DAP as a huge improvement from my smartphone.
post-13322281
Post #4,990 of 21,843
mikamo
Hello Paul. I just purchested DX200 Yesterday!
It sound great so far, as everybody mentioned.  I just have some concern about music sorting by meta tag.
Is there any setting to sort music by it's meta tag? If not , Can you put it on?
It is really important to sort music files for some of the classic albums and I prefer not to edit file names nor create playlist one by one.
post-13322306
Post #4,991 of 21,843
truenobzr
Hong Kong
Hong Kong
Do anyone have frequently auto reboot problem?? I have this problem in my old and newly replaced DX200, either old and latest beta firmware.
post-13322332
Post #4,992 of 21,843
jamato8
I don't think you have wasted time but I like to use headphones also. Because of the varying impedance of monitors I think it burns a system in differently. I have no edge or grittiness compared to the 1Z or Hugo, just nice and clean. I would try a headphone for a while also.
post-13322335
Post #4,993 of 21,843
jamato8
I don't have any. Did you try a factory reset and have you checked the card or are you using the internal memory? If it keeps up I would try the batch tool on the first page.
post-13322341
Post #4,994 of 21,843
bluesnote
Yup! Happens to me often this new firmware it messes up my Spotify too(logging out then when logged in it does not show the downloaded files, yet downloaded music are still in SD card)
post-13322376
Post #4,995 of 21,843
truenobzr
Hong Kong
Hong Kong
it happens only in Android mode so far... I just had my replacement and installed the latest beta once I got the unit, I don't think a factory reset is needed.
Users Who Are Viewing This Thread (Users: 0, Guests: 7)
