DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
320 321 322 323 324 325 326 327 328 329
331 332 333 334 335 336 337 338 339 340
  1. Dizzle77
    Cheers
  2. kevindiu
    Dear Paul,
    My dx200 has a lot hiss problem, even higher than my 300r, how can I check my device is affected by hardware or software? Is my device is not good?
    Regards, Kevin
  3. all999
    Are you connected to WiFi? 2,4 or 5 GHz?
  4. Paul - iBasso
    Have you tried reloading the firmware? You can also do a  factory reset and try the Batch Tool on the first page. Do you hear hiss with any headphones or IEMs that you use?
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
  5. kevindiu
    Thanks for your reply.
    Yes, I installed my firmware and even using batch tool and factory reset. I am using Cosmic Ears CE6P with balanced.with the same headphone and cable I cannot hear any hiss from my 300R.
    Update: airplane mode always on, so no wifi or anything else is on. Even with mango OS the hiss still consist.
  6. koluludome
    Which driver I have to install for windows10 64bits to use factory tool ?
  7. WindowsX
    win8 ones.
  8. icefalkon
    Wow I'm floored by this "charging" for ROM's. What is the benefit to buying the ROM's WindowsX?
  9. koluludome
    Thanks for that
    First impression, Android mode is good. Touching is fine. Launcher3 is closed for a few time. Mango OS can't see anything in microsd card while Mango app is doing fine.
    Find a way to get a normal version but seems like you have cut a local update feature off ?
  10. WindowsX
    Is this sarcasm or you're genuinely interested in purchasing advanced ROM? If it's the latter, feel free to send PM and I'll send you info about advanced ROM. Cooking good ROM takes a lot of time and effort more than you think and I've already spent nearly 100hrs working on DX200 ROM (Not on free ones though). If you don't like to pay, you can still use free and good ones.
    I recommend to do full wipe if you experience force close bugs. It didn't happen to me and all during my tests. I only tweak video rendering and storage I/O stuff a little, removed audio effect files and add Play Store and Apollo app. That shouldn't introduce those bugs.
  11. koluludome
    WindowsX I tried this with your instruction but will find a way to do full wipe. Thanks.
  12. HiFlight
    Perhaps the marketing and discussion of WindowsX ROMs should be limited to his thread rather than taking the DX200 thread off topic. Seems it violates MOT posting rules regarding advertising.
  13. WindowsX
    Before flashing, you can change the option from upgrade to restore ones instead. It'll format and do full wipe for you. It could also be bugs from 1.3 to 2.0 ROM without wiping too.
  14. Mimouille
    Paul - iBasso
    The new beta firmware is freezing halfway through the update with the little android guy. Anything I can do?
  15. rmap
    Is there any estimate of when DX200 will be available again on the iBasso web site?
