Rawrbington
- May 12, 2011
what about the darkvoice 336 or schiit valhalla?
Yes, I barely hear a difference of dynamics between my iMac and the LDMK2 powering the 600Ω Beyer (besides the obvious huge increase in volume capacity and subdued treble by the mallard drivers) I'm wondering that at this point it's more worth it to upgrade to a very expensive amp, or try and sell my 600Ω Beyers for a lower impedance version. I'm getting the Denon D2000 in shortly so it'll be interesting to see if I can hear a noticeable upgrade in dynamics in that coming from iMac to LDMK2.
Yeah I have the 336, best I've heard for the 880s. I would say no to the Valhalla but possibly to the Lyr depending on driver.
I wouldn't consider either with a cheap op-amp driven solid-state, especially not an E9. If you can afford a high-gain tube amp (around $300+) go with the 600Ohm Beyers and you'll be set for a long time. Alternatively if your budget lies around a Beyer and an E9 I'd favor a less demanding phone and possibly hold off on the amp until you can afford the pair.
have you had a chance to hear the Valhalla with the 600 ohm beyers?
i was under the impression it was an OTL amp designed to drive high imp cans
Oh there you go again with your mis-information. You do understand the E9 is not a portable amp right? Acting as if the E9 has trouble driving ANY DT-880 is just crazy talk. I do think even the 32ohm Beyers need an amp and would never suggest them without one. It's good you have an opinion, but I can't let this one pass. As always, get the best amp you can afford. Many people just avoid amps, so the E9 or anything else at it's price point is a good place for them to start. Better than nothing.
I suggest ignoring Graphicism and listening to people who have owned the E9 or actually listened to it for more than 10 minutes. Highly unlikely he has.
So what is it about the Darkvoice that differentiates itself from the Little Dots? I already ordered the D2000 and it's on its way, and I'll probably like it. I'm not after the extreme fidelity in sound, but I want the best sounding-fun sonic signature. Hopefully the Denon's soundstage is relatively good for a closed hp. Besides that it gets wide praise.
I have and I didn't think much too it, I haven't heard the Lyr however from reading people seem to like it with their orthos which are also power hungry. OTL simply means it doesn't have an output transformer to reduce the high current, this is extremely common in cheap tube amps, the benefit is they are better equipped to handle higher Ohm phones. The benefit being a lower ground level and low distortion, you couldn't however guarantee a good match with a particular phone.
I guess I'll look into amps a bit more before I order the headphones. Or maybe look into the 250ohm, but considering its the same price it would seem more worthwhile to invest in something that can power the 600ohms proper.
You're quick to point the finger. In fact looking at your profile and the cans you've been through with the low-gain, highly portable amps you're the type of member I am referring too. You're saying the E9 is fine because it's as good as several other low-gain and/or portable amps you've compared it too, when in fact you haven't heard a properly amped headphone at all. I am not saying don't bother with the E9, I am saying DT880 with an E9 won't be much of an upgrade from an AD700, however for another $100 a high-gain tube amp would be a huge upgrade. The problem I have with Fiio products is like Beats they are all marketing, for less than the Fiio DAC/amp combo you can buy a Zero DAC/amp, this has nothing to do with money and more to do with marketing which you're overly susceptible too.
It's very easy for someone to come to this forum, be suggested an E9 to power a DT880/600 for example and then a few months later be suggesting this combination themselves and additionally slamming anyone who says anything negative about their equipment. When in truth they haven't heard a proper amp, there headphones are under powered and they are non the wiser.
i wish i could find the sensitivity ratings for the 250 ohm and 600 ohm beyers (decibels per milliwatt).
however, i'll just have to share anecdotally, that most folks would mistake the 250 ohm beyers as "twice as easy to drive" as the 600 ohm siblings.
However, this isn't anywhere near true.
In fact, they are almost as hard to drive.
You see, powering a headphone isn't just about impedance. It's also about sensitivity.
The 250 ohm beyers, while being of lower impedance, also have slightly heavier drivers, making them "nearly" as difficult to achieve similar sound pressure levels.
