I've used a lot of amps (including some of the nicer tube amps, and I've got access to NOS tubes too though I really don't like using them, relying on something you may not be able to replace isn't a great idea imo) and I find the E9 does fine with a wide range of cans! It's got enough voltage to reproduce dynamic material without significant distortion (a real issue with 9V-powered amps and higher impedance cans) and can pump enough current to satisfy the more demanding but lower impedance headphones. Plug an HD-650 into it and an AKG K701 into it and the volume level is about the same, even though the HD-650s have a much higher impedance peak and general impedance. AKGs are some thirsty friggin' cans. Beyer DT-990 250ohm are the sweet spot, in my moderately humble opinion (hey, if it were really humble, I'd keep it to myself).
I think there's some (understandable, forgivable, but nonetheless) elitism going on there... Yeah, you're going to get better results with a really nice amp, but stepping back from everything except construction, specifications and the stuff that's measured in physics rather than price of entry, the E9 is pretty remarkable. A game changer at the price point, puts adequate power into the hands of anyone who previously might have been limited to a cmoy or something like it. I don't mean anything more than adequate, mind you, don't raise hackles, there isn't any insinuation here.
I don't have any personal bias pro/con discrete or chip (I do like small circuits so ICs are neat to me from a technological standpoint and I work with them in my day job, but when it comes to headphone amps, matters not - just results - dig it...), and I don't have any personal preference for class A vs. other power amp technology anywhere but my guitar amp. Which is class A tube. But that's because I want it to sound nasty and run hot! Not qualities I necessarily look for in a headphone amplifier! But, please, take this peacefully, as it's offered, not as a challenge. I only mean to point out the adequacy of the E9, not to challenge better, pricier gear as inadequate or equivalent.
I love the DT-990, the DT-880 strike me as being just a tad bit... I dunno, less profound. But that's not a bad thing, necessarily. They would make a good pick if I could only have one headphone and it had to be high end but still affordable/in reach of anyone seriously into the hobby. I suspect I'll pick up some T1s soon, big fan of Beyer's overall style and sound. If I had to have one pair of headphones to compliment my monitoring setup and I was given a budget of $400 and it included the amp (not counting a DAC since that's assumed in an audio production setup obviously), DT-880s and an E9 would be a pretty good pick. Not quite as much of a "magnifying glass" on the upper midrange and highs as some other cans (specifically AKG K701/702/Q701 come to mind, here, such detail for the money, you'd have to spend twice the price of the AKGs at least, per monitor, to achieve remotely comparable detail in the highs), but the DT-880s do put forward a very balanced presentation, and man are they comfortable. Beyer knocks comfort out of the park. Wear 'em all day, listening to stuff or not, they're just pleasant on the head.
Has anyone told him that Beyers are REALLY REALLY SENSITIVE TO PLACEMENT ON YOUR SKULL yet? If you veg out for a sec and they slide back half an inch, you've just changed the overall frequency response dramatically. Roomy ear cups unless you've got some seriously large ears (I've got big ears! I can say that!), and a fairly loose fit, plus really plush earpads... Careful to put them where they sound best on your head. Big changes a few CM forward or back!
