I just checked Cowon Global and the website does not have Firmware 1.15 on the list so be careful.
^ Agreed. The update of 1.15 is for the M not the D.
Arrghhh could somebody help me choose between the dx80 and the plenue d pleeeease?
I really am stuck
I've been reading forums and tests for 2 days and i cannot make my decision!
I'm mainly listening to electronic music (tekno/psychedelic...) but i really enjoy fusion jazz.
I'm used to monitoring speakers (not the greatest but not the cheapest)
What would you recommend me betwen the cowon plenue D and the ibasso dx80 ? (or anything in that pricerange but I think i've read about all
Thanks !
Aany idea why my cowon plenue D is not showing flac and that when playing mp3 it doesn't show the right cover art?
I use firmware 1.14, and I have 1250 files or so, flac are usually 1 bit 44.1khz some are 24bit 192khz none are showing.
Thanks man, I think i'm gonna go with the plenue D then =)
He should also make sure the album art jpg/png are labeled as "cover.jpg/png"
I really am stuck
Thanks !
You won't be sorry, my only complaint is the current size of 128gb micro sd. Had a 200gb ready to plug in but only read so much of the card, the rest of the music was unplayable.
i have my 128gb maxed out and the onboard memory almost maxed. Jet Effect, possibilities are endless with presets and 4 user defined sets.
I don't know if you're using Mac Os X but I found out a few days ago that you can enter a script that allows you to view hidden folders in Mac os x. I did this because my 128gb/ 32gb was maxed out, any ways I was able to locate the trash folder hidden within the sd card/ pd and found about 40 gigs of files that were not deleted thus hogging up space.
Once I deleted these files I suddenly had 40 extra gigs to play with.
I have both the DX80 and the Plenue D. Both sound good to excellent Here is my 2 cents worth.
Benefits of DX 80: can use an external amp to drive whatever headphones and two microSD cards.
Benefits of Plenue D: everything else (scanning of files, battery life, equalization, ease of use, size, etc.)
So if you mostly use easy to drive IEMs, earbuds or headphones, the Cowon will suit you fine. If you will use the line out option, the Ibasso is nice or there are great options for not too much more.
