Cowon Plenue D
Dec 3, 2016 at 12:09 AM Post #3,711 of 4,949
When the first time I heard Fiio X1 it was paradise. Then I bought the Fiio Olyumpus for my PC. then Fii0 X1 when crazy, So I bought Cowan Plenue D.
After the firmware upgrade then it sound nice. funny when I add SD card it can't read. So I have to use a third party SDformat, to format the SD.
Now I  order the Acoustic Research M20  hi res player, it should be great. I was eying the Acoustic Research speaker for years.
Earlier I intend to upgrade to Cowon P1 Plenue. But so many people is selling it away. why? so I drop the idea and go for Acoustic Research M20.
Dec 3, 2016 at 10:35 PM Post #3,712 of 4,949
Aany idea why my cowon plenue D is not showing flac and that when playing mp3 it doesn't show the right cover art?
I use firmware 1.14, and I have 1250 files or so, flac are usually 1 bit 44.1khz some are 24bit 192khz none are showing.
Dec 4, 2016 at 1:36 AM Post #3,713 of 4,949
The cover art could be because of folder art jpeg in the folder.  For some reason when album art jpeg is in the album folder it causes the PD to show random art.  I have no idea about FLAC files.
Dec 5, 2016 at 8:57 AM Post #3,714 of 4,949
Does anyone has allready tested the new firmware? (v1.15 b2)
It says that the output voltage has been lowered from 1175 mV@32 ohms to 150mV@32Ohms !!!!
It's a HUGE drop, will this affect my listening in any way? (Thinking to buy one soon, still hesitating with the ibasso DX80)
Does the player will still be able to output @ 1175mV ???!!! (My headphones are Audiotechnica's ATH-m50x@38ohms)
If not was is the point of having such a output power if not to be able to use it?
What europeen norms !
PS: I enjoy listening to all sort of music from electronic (tekno, acid, trance) to jazz what would you advise me ? I'm hesitating between the dx80 and the plenue D
Thanks !!
Dec 5, 2016 at 9:09 AM Post #3,715 of 4,949
Thanks !!
It's from the french Cowon website... I wouldn't touch that update!
Dec 5, 2016 at 9:14 AM Post #3,717 of 4,949
  What if when I buy the player the update is allready installed?
I'll not be able to drive my headphones right?
You can downgrade the firmware easily...
You can also download the firmwares on the cowon global website (any version).
Dec 5, 2016 at 11:37 AM Post #3,719 of 4,949
Try changing the file extension from .flac to fla. Im having the same problem I sort of solved it using this method.
