Cowon Plenue D
- Thread starter AeroSatan
kaneman
- Nov 29, 2010
Is this player buggy at all?
Not very. But it does seem to struggle once a larger number of tracks are added. Mine choked on a full 128GB card until the latest 1.13 firmware update. I believe there's about 4500 songs on it.
kaneman
- Nov 29, 2010
Hi clee290
Thanks for coming back - to clarify:
I have assumed that the new tracks caused the problem, this may not be true. So I deleted them to see if somehow the problem might be related to a memory issue related to them. But this might be a red herring.
The problem exists now the new tracks have been deleted. To make the problem more clear:
1.I hard reboot (- and + volume)
2.The reboot happens
3.Returns me to the track list
4.Can use the menu to navigate to settings, tools etc, and to artists and albums
5.When I click a track the player shows the play screen with the track listed, the pause button appears suggesting it is playing, but the unit is now frozen and the seconds counter at 0
As I mentioned before the only thing I could think of is updating the firmware to see if that cleared things, but this did't work.
Apologies, my prior post lacked enough detail, appreciate any thoughts on this
Cheers
May be an issue with overall number of tracks? How big is the card and how many tracks?
Does the D have Line Out?
- Jan 10, 2016
nopeDoes the D have Line Out?
IMHO that is depend on player you have in your iPhone. With basic preset player is D better. With some like Kaisertone is gap between them nearly none.
Hi mrazik!
Vitor and I did a bunch of blind tests with his Plenue D and my iPhone 6s Plus, using the same tracks on both (that we are used listening to), 320kbps and we could not once identify which player was playing. They are virtually indistinguishable.
The iPhone player used was the Apple Music player.
Earphones used were JH Audio JH5 and Fischer Amps FA-3E.
Vitor Valeri
- May 8, 2011
Should I format the internal memory using fat32 or exfat?
FAT32 file system with an allocation unitsize of 32 KB.
Vitor Valeri
- May 8, 2011
Hi
I just got my Cowon Plenue D and I am experiencing issues.
The problem I face is that I am hearing very audible pops and clicks (only on the left channel) on almost all of my mp3 songs when I am playing them. This happens almost continuously throughout the song,
The weird thing is that this only happens when the display screen is off. When the display is on, there are no pops nor clicks
Everything is fine when the display is on but if I turn off the display..then I hear those annoying clicks and pops again.
The problem exist when I was using firmware 1.10 as well as the current 1.13. The problem is also still there when using the SD card. I had also turned off BBE and EQ..still the same problem. I had scanned my files using Mp3val and everything is fine.
I'm going out off my mind. Any help is much appreciated.
I created a topic dedicated to this problem: http://www.head-fi.org/t/812142/cowon-plenue-d-problem-noise-during-the-exchange-of-track
Post it your case and the solution if you can please.
jmills8
Previously known as bmiamihk, jmills2
D with a good amp sounds great.Got it. I guess I'm double amping should I get this baby!
- Jan 10, 2016
im pairing this with nx1. synergy is great
kimD
- Feb 5, 2016
By any chance any of you owned or still has the Fiio X3 (1st Ed)? Can you do a quick SQ comparison please?
- Jan 10, 2016
i tried the fiio x3 1st gen b4. the sq is on par i would say but cowon gives me the slight edge.
Total: 7 (members: 0, guests: 7)
